Ultra Simple Class D
Old 27th March 2013, 01:40 PM   #301
norazmi is offline norazmi  Malaysia
yes, it will work with proper design, sending u an email now.
Old 27th March 2013, 02:28 PM   #302
JLesterP is offline JLesterP  Philippines
Hi Azmi,
Im planning to put NE555 for the delay and an optocoupler for shorting the U1B output to ground. I also want to use LM311 for the comparator because I already used it in one of my prototype amps and achieved good results. But it will consume too much pcb space.
Did you experience good results with small signal transistor (eg. 2n5401) for current sensing trigger? If it is good, and doesn't have false trigger problems I think I will use it instead of LM311
Old 27th March 2013, 02:44 PM   #303
idk, but using transistor is not good, sometimes your power transistor safe and some might not, and without delay is more worst happens. better you go with ne555 and LM311, so far it did good job with ucd amp that i already test before, yea little more space it not a problem .
Old 28th March 2013, 10:17 AM   #304
Thanks, I just created a daughter board that can be attached on top.
The protection circuit is already tested in my other class d amp.
Here's the preview
Old 28th March 2013, 10:47 PM   #305
good pcb, but the protection circuit need to be test
Old 29th March 2013, 06:15 PM   #306
Tekko is offline Tekko
Banned
Another way to accomplish a super simple class d amp if lots of power is not the goal is to use mosfet gate drivers as output stages. Though with IXDD430 and BTL mode around 100 watts is possible into 4 ohms as these gate drivers can take up to 40V wheres the others are limited to max 18-20V.
Heres a BTL UcD i prototyped using UC3710's as output stages:
Old 7th April 2013, 11:38 AM   #307
Hi no need to test the protection circuit, as I said before the protection works flawlessly on my other class d that I've created.
Old 7th April 2013, 12:20 PM   #308
thats working irs1500D o4 irs3000D from detex audio which this circuit already meet the requirement for the protection, but we are talking about this cheap class D and let see if it will working same way.
Old 7th April 2013, 05:51 PM   #309
stewin is offline stewin  Kenya
hi all you can use manojs protection which is good and working it is discreet and uses 555timer to shutdown ir2110 but in this case it can be modified to fit this amp.
Old 11th April 2013, 10:39 PM   #310
hi all i made the few modifications .now it is better and can run with 2n5401 and 2n5551 as drivers.
Ultra Simple Class DHide this!Advertise here!
FETish: ultra-simple transconductance amp Mr Evil Solid State 38 13th May 2009 11:07 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 06:04 PM
Copyright ©1999-2017 diyAudio
