Ultra Simple Class D
Old 18th November 2012, 02:26 PM   #281
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
2x Iron Powder Toroid Core T200-2, Iron Powder Toroid Core T157-6 items in urbasket eu store on eBay
this URBASKET EU STORE is a ripper please be careful in dealing with him ARTHUR
i hvae still not got my 10 t157-2 cores 3 MONTHS have passed
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 18th November 2012, 09:20 PM   #282
Hadighorbani is offline Hadighorbani  Iran
T106-2
Download T106-2.zip
Old 18th November 2012, 09:29 PM   #283
original T106-2
Old 18th November 2012, 09:49 PM   #284
dfuhr7gm is offline dfuhr7gm  Austria
damnit so many cores! :O haha
Old 19th November 2012, 04:27 AM   #285
it is for all off DIY and iranian boys my friend
i can send it to all by DHL post
Old 11th December 2012, 02:02 PM   #286
beethovenj is offline beethovenj
Default Connect Trasducer to this circuit
Hi!
Nice simple class D amp!
I was wondering if this amp would work fine in the 38-42 kHz range and what to do to connect it to a high impedance piezoelectric transducer (custom transformer I suppose). I want to start playing with relative high power ultrasounds
Thanks so much for any tip!
Old 1st January 2013, 12:23 PM   #287
JLesterP is offline JLesterP  Philippines
I've created a layout for this one.
I added trigger for protection circuit and added gate resistor diode.
Also adjusted some values for slightly higher than +-50V operation.
You can opt for the original values if you want it to run it for lower voltages.
I added the fuse so I can easily route the GND trace haha.
Old 1st January 2013, 02:35 PM   #288
stewin is offline stewin  Kenya
have you tested it with +/-56vlts successful , do the outputs or gate drivers heat or operate normal at that voltage ?
Old 1st January 2013, 03:00 PM   #289
Haven't tested with that voltage yet. So to be on a safe side run it at +-50VDC first
Old 25th March 2013, 04:56 PM   #290
Here's my compact layout based on original schem by ejtagle.
Ultra Simple Class DHide this!Advertise here!
FETish: ultra-simple transconductance amp Mr Evil Solid State 38 13th May 2009 12:07 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 07:04 PM
Copyright ©1999-2017 diyAudio
