Ultra Simple Class D
Old 2nd September 2012, 01:45 AM   #251
stewin is offline stewin  Kenya
Originally Posted by CPX View Post
Use resistive load for testing...don't you care about your speakers and your ears?.
Also any amplifier must survive continuous rms power into resistive load to be reliable with music.
resistive loads like ? resistors in parallel to match impedance desired?
Old 3rd September 2012, 12:43 PM   #252
sweetperfume is offline sweetperfume  India
Cpx, Resistive load means a speaker...and non-resistive means a resistor load.. .
Old 3rd September 2012, 02:41 PM   #253
CPX is offline CPX  Romania
sweetperfume:
No,the opposite is correct.
A speaker is a non resistive load, in fact it is a nonliniar inductive/capacitive/resistive system depending on its configuration(single or multiple in cabinet and with or without filters).
stewin:
Power resistors with their resistance smaller than rated impedance, example: for 4 ohm impedance use 3 or even better 2.5 ohm low inductance resistors or resistor network
Old 8th September 2012, 07:53 AM   #254
mgee is offline mgee  South Africa
how can i simulate class d with ni circuit design suite multisim
Old 8th September 2012, 08:16 PM   #255
Tekko is offline Tekko
Banned
You simply draw the schematgic, assuming multisim has models for the components used, which as far as i know it should.
Old 9th September 2012, 06:39 AM   #256
ni multisim doesnt hav models for ir2110 or irs2092. i hav seen several class d schematics with these two componets but i dont knw which cad was used. can anyone cum to my rescue please.
Old 9th September 2012, 08:16 AM   #257
Banned
There are models available of the IR2110 for Linear Tech LTspice switchercad.
Old 12th September 2012, 04:37 PM   #258
Macleod is offline Macleod  France
The schematic post 246 showing bridged class D may experience problem. Both halves may oscillate at different frequencies and some intermodulation product may be heard.
Bridge class D amp should be done using the same modulator or synchronized modulator.
Old 24th October 2012, 06:18 PM   #259
hi all just found this schema by detex audio . it seems simple . what makes it 100watts and not 200 watts?
Old 24th October 2012, 10:52 PM   #260
Hlaford is offline Hlaford  Croatia
Supply voltage? If I was not this lazy I'd make a LTspice simulation of this circuit to see what it is capable of, but on a first look, the supply voltage could be ramped up for some more power.
Ultra Simple Class DHide this!Advertise here!
FETish: ultra-simple transconductance amp Mr Evil Solid State 38 13th May 2009 12:07 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 07:04 PM
