Go Back   Home > Forums > Amplifiers > Class D
Old 25th January 2012, 03:36 PM   #1
Default First Class D sub amp
Wondering if anybody can point me to designs for a decent class D subwoofer amp?
This is my first audio project, although I'm well familiar with building electronics already. Budget is a concern, so I'd rather build it slowly, buying all the bits over time, than drop a lot on a kit.
I'm leaning towards quality over power, I don't really need it to deliver over 80 watts, in fact 50 or 40 would probably be fine. Obviously it would be mono and designed for the low frequencies of a sub. My passive sub is running from a pretty terrible loaned eltax amp at the moment and I want to build this amp to replace it.
Many thanks,
K.
Old 25th January 2012, 09:55 PM   #2
nigelwright7557's Avatar
You can pick up a ready built pcb for less than you could build one yourself.
There are loads on ebay.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 26th January 2012, 12:50 PM   #3
Thanks, but I'm not interested in a ready built one, that's why I'm on this site. Can anyone else help?
Old 26th January 2012, 01:15 PM   #4
41Hz Audio - Main page has a lot of kits, that you have to solder yourself.
Old 26th January 2012, 01:38 PM   #5
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I´ve designed one of my own, and it have been working fine too the moment I put it out of service. The idea was a HCF4047 oscillating to 500KHz, divided internally by two, and out of fase from pin10 & 11.Two signals was integrated on an differential integrator around a 1/4 TS274. From here a pretty triangular wave, entering TS3702 push pull comparator, the other input receive audio amplified. From out TS3702, a HCF4049, a IRF9120/120 and then IRF9740/740. Double inductor and double capacitor (Four pole filter) and a small feedback loop from before filter, integrating to recover audio, and going to inverting audio input. All this with +12/-12V, except HCF´s working +6/-6V, all DC coupled. Simply but effective. I have the circuit in OrCAD SDTIII format if you like it.
A veces pongo un circo y me crecen los enanos...
"Que se llama soledad", Joaquin Sabina, el capo.
Old 30th January 2012, 01:39 PM   #6
Osvaldo: sounds excellent! The schematic would be great, if you'd be so kind
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Page generated in 0.09048 seconds (74.85% PHP - 25.15% MySQL) with 10 queries
