Soft Start, Loudspeaker protection or other? HELP!
Old 21st January 2012, 07:26 PM   #1
JohnsonAV is offline JohnsonAV  United States
Default Soft Start, Loudspeaker protection or other? HELP!
Hey All,
I've got a turn on/off power popping problem that I need to fix. My setup is as follows: miniDSP (2x4 Balanced) powered from one of two B&O 250ASX2 amp modules via 24v/12v regulator/voltage divider. I've got the two B&O's connected directly to an IEC input w/ switch (they have integrated SMPS w/ an Aux DC out). I believe the miniDSP is the source of the popping since it's not as severe when I disconnect the signal cables from it.
So, how should I approach this? Soft start circuit? (but the miniDSP gets its power from the B&O) Loudspeaker Protection Circuit? (maybe, but I have 4 channels...and not a lot of extra room.) Some sort of amplifier enable switch that is triggered with a relay with a delay? I think it might work but I have no idea how to build such a device...help?
thanks!
Old 22nd January 2012, 03:43 PM   #2
dtaylo3 is offline dtaylo3  United States
good inexpesive soft start from Connex Electronics
Old 23rd January 2012, 03:23 PM   #3
Thanks, but I'm not sure it will work with my DSP powered off the amp(s). Is there a way for this scenario to work - power switch on -> DSP turns on with "mute enabled pin" engaged on B&O amps -> xxxms delay -> "mute enabled pin" released. Power switch off -> "mute enabled pin" engaged -> xxxms delay -> DSP turns off. Essentially I'm looking for a sort of power sequencing or timed mute relay function that all happens in the same chassis.
Soft Start, Loudspeaker protection or other? HELP!Hide this!Advertise here!
Soft Start and Speaker Protection Tripmaster Chip Amps 17 11th December 2013 10:31 AM
Speaker protection and soft start modules from Aussie Amps chlorofille Swap Meet 5 18th July 2011 09:58 PM
Soft start and DC protection for Aleph J 3GGG Pass Labs 10 10th May 2011 11:45 AM
Soft Start and Speaker Protection PCBs needed Jan Dupont Swap Meet 12 17th September 2008 12:05 PM
Soft-start integrated with DC-protection? darkfenriz Parts 7 18th February 2006 10:33 PM
Copyright ©1999-2017 diyAudio
