L25D Toroid
L25D Toroid
Old 14th March 2012, 08:24 AM   #11
Demidemon is offline Demidemon  New Zealand
Originally Posted by redjr View Post
Hi - I have a basic question about transformers. When a x-former has dual primary inputs (115v each), these are normally connected in parallel to maximize x-former current output on the multiple secondary taps. Is that a correct statement? Is it also fair to say that if only a single primary winding were used, you'd essentially get about half the current on the secondaries? I just want to make sure these primaries can be connected in parallel for standard operating configurations. ( It's been a long, long while since my basic electronics courses, and just want to make sure I don't melt my spanky new toroidal.)
Yes, I'm pretty sure that you're right. The reason that there are two is of course so that in a country where the mains voltage is 230V they can be run in series.
One of the first things I do if / when I get an amp (or a computer) which has a switch for either is fire up the hot-glue gun and make sure that it can't be switched easily. I'm in New Zealand where we have 230V and I'll never forget when a pupil at the local high-school switched all of the computers to 115V last thing before going home. Apparently there were lots of expensive bangs the next morning when the first computer class of the day started. (It was a while back, before PSUs had all of the safety stuff the newer ones have.)
Old 18th March 2012, 03:51 PM   #12
sketchyphish is offline sketchyphish  United Kingdom
sketchyphish's Avatar
L25D Toroid
Hello just an update, seems that this is indeed a standard toroid, upon separating the two blue wires she does indeed have two separate windings in and out.
I have started a thread about thermistors as atm i need to get a suitable soft start to cope with the toroid, rectifiers and caps.
L25D ToroidHide this!Advertise here!
L25D sketchyphish Class D 5 19th May 2015 10:30 PM
Toroid? billbeau Chip Amps 3 4th November 2008 03:26 AM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 03:49 AM
Toroid question amisdad Chip Amps 6 25th September 2004 07:59 AM
