Class D Crest factor?
Old 14th January 2012, 08:45 AM   #1
eem2am is offline eem2am
Banned
Default Class D Crest factor?
Hello,
Can you confirm, that it is physically impossible for a Class D amplifier to be able to draw more than peak_power/2 continuously?
Old 14th January 2012, 10:05 AM   #2
Cristi is offline Cristi
Banned
You ask who? :-D
negative. it is possible, as long as you drive the amp with max. amplitude of the input signal. in fact the amp will draw the output power / eff. i do not comment weather or not can withstand this for long term, this depends on the particular design. imagine that you use a class D amp to drive whatever load needs a continuous wave, sine or other shape, a particular example is a DC-AC inverter, who
Old 14th January 2012, 11:04 AM   #3
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Originally Posted by Cristi View Post
You ask who? :-D
negative. it is possible,.... who
Most of them has over current protection at its supply. So high current that higher than the current protection treshold just work until capacitor discharged and protection work in.
Old 14th January 2012, 11:59 AM   #4
iand is offline iand  United Kingdom
Originally Posted by eem2am View Post
Hello,
On an unclipped sinewave, this is obviously the case by definition for any amplifier.
On a squarewave, peak and average powers (and voltages, and currents) are the same.
Old 14th January 2012, 12:21 PM   #5
Banned
Originally Posted by ontoaba View Post
...WHO
I was writing the reply while the forum went to sleep for the daily maintenance. when i pushed submit, just part of the message was posted. can be deleted. anyway i forgot my idea.
Old 14th January 2012, 06:55 PM   #6
Banned
-ok, i see your meaning, though i used to work on SMPS for flat screen TV.
I did loads of thermal tests on the flyback which supplied the Class D audio amplifiers.
I distinctly remeber that at peak audio power, the flyback failed the thermal test by a long way.
However, no managers were concerned.
-Because all they were bothered about was that the flyback could continuously supply peak audio power divided by three....which it could.
Given this fact, on these TV's which are sold the world over, how can we be saying that Class D amplifiers can supply more than peak power divided by two.?
Old 14th January 2012, 07:05 PM   #7
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
That's a very conservatory specification. If I were in the finance department of this company I would demand why these engineering managers agreed to a too high specification. Continuous output is typically -9/-10dB or 8/10 times lower than the peak output, so 3 times lower is a very conservatory specification and it probably should have been even lower at peak power divided by 4 or even 6, to give at least 50% headroom. 200%+ headroom seem exaggerated.
Naturally that could be tempered by the opposite cost of needed large capacitors but it was something I would definitely address if I was in your finance department.
Old 14th January 2012, 07:50 PM   #8
Banned
OK thanks, in my post (2 back) i accidentally said the Class D was supplying.....of course, i meant the smps (the smps that supplies the Class D
amplifier.)
or rather , that the class D amplifier "draws" power
Anyway, Heatsinked fets heat up in about 2 seconds, so i wouldnt want to de-rate that much.
Old 14th January 2012, 08:25 PM   #9
Saturnus's Avatar
They're only at peak output for a few microseconds or picoseconds at a time though, or roughly 10% of the time as noted above so why should it be a concern?
Old 17th January 2012, 01:02 AM   #10
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Detecting a too hot power supply is far easier than detecting a too hot voice coil.
Replacing a shorted diode or transistor is easier than replacing a couple of TV speaker drivers with custom sizes and specs.
I use to feel like the small child in The Emperor's New Clothes tale
Class D Crest factor?Hide this!Advertise here!
Crest Factor ... how does one use it? Don Snyder Subwoofers 8 17th November 2010 04:03 PM
Preamplifier damaged explosion Class-d Crest lee1976 Class D 2 21st November 2009 06:39 PM
Class T - maximizing damping factor, any ideas? Disney_SK Class D 51 22nd June 2008 12:56 PM
Power Crest Factor ChocoHolic Solid State 15 2nd April 2005 06:46 PM
Copyright ©1999-2017 diyAudio
