Sure Electronics 2x300W (TAS5630) & 2x250W (IRS2092) - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st September 2013, 01:16 PM   #31
Send a message via Yahoo to ionutzxpo
Hello guys, i recently buyed one amp with power supply from sure-hifi (ebay) and i saw there was a warning there (DO NOT power the amplifier board when there's signal input, or the chip will be burnt out. It's suggested to plug RCA jack first, stop signal input and then power the amplifier board. Finally, Begin signal input after 1 second) dose anyone had this problem? this sounds absurd to me.That means, the amp is very unstable.
Iacob Ionut
Old 4th October 2013, 11:22 PM   #32
this bundle tas5630 and power supply 350w title says 300w x2 and in same title power supply 350w ..wtf but ok should be around 100w rms per channel..and when i found that line about burning amp when playing music and disconnect from mains i ordered it in matter of seconds they bougt me on that ...try to guess what will i first do when amp comes in my hands
Old 15th December 2013, 01:06 PM   #33
Don't order TI TAS5630, its sound quality is not good. I've ordered 4 IRS2092 2x250W boards and sound quality is much better. It uses dual +/- power supply and at high voltage values (+-60V) with low resident noise and lower THD+N (only 0.007% at 100W). The sound quality is very very good. I use a 2KW toroidal transformer and two Nichicon 100.000uF capacitors in power supply stage.
Old 16th December 2013, 09:14 AM   #34
Originally Posted by authlxl View Post
Our tas5630 amp revised many times now, works stable, all the chip are TAS5630B now,many friend ask us for the reason why not develop tas5631b PWM input amp, we think it is same chip indeed, only add low frequency pass filter ahead.we think PWM is analog not digital indeed.if use tas5631b, we have to add one i2s to PWM chip , cost higher.
Good suggestions are appreciated, Many thanks!
But cost of I2S to PWM are probably cheaper than a good DAC. I once owned the panasonix SA-XR55 (don't no which TAS chip). Analouge input was bad sounding, but digital spdif was really good.
Old 11th June 2014, 10:21 PM   #35
What has your experience been so far with this amp?
Old 15th June 2014, 01:23 AM   #36
this probably tas5630 not b i got wont blow up and i use 42v dc 7,5a toroid and 4 ohm speakers
Old 28th June 2014, 03:58 PM   #37
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
Default Stable TAS5630B amp module with SMPS unit all in one board
latest Version TAS5630B board completed, it is G300V33 series, G300V33BTL is 2channel module, G300V33PBT is mono channel module,
Very stable now, shorted output together anytime no problems.
Dynamic limiter support,
DCP /OCP/ UVP/OTP protections, even POWER LEVEL control system added, this function can make the module RMS power about 400W total.so the chip can run under safe conditions.
Key benefits
Backup DC supply system, suit for solar or car system application.
A wide set of features for plug and play implementation into applications such as active speakers or proaudiosystem.
Black-box design, module have good heat dissipation and better EMC performance.
Advanced protected function against short circuits, overload and overheating and includes on-board fuses and EMI filtering that provide a CE and FCC pre-approved design.
Key Specifications
.POWER OUT:
G300v33BTL 2200W/ 4Ω@1%THD+N /2 BTL MODE
G300v33PBT 1X350W /2 Ω @ 1% THD+N /1PBTL MODE
.FREQUENCY RESPONSE: THD+N ≤0.05% / 20-20KHz / <1dB/1W
.INPUT SENSITIVITY: 0dBV(1Vrms/BAL input)
.S/N: 98dB(AES-17/A-weight)
.POWER SUPPLY: 110VAC OR 220VAC 50 OR 60Hz
.AUXILIARY POWER: +/-14V @ 500MA max
.DIMENSIONS: 160MM(length)*80(width)*52mm(height)
.NET WEIGHT: 0.46Kg
Key Features
Balance input and balance output design, Hi-Fi sound design
Multilayer PCB and thickness copper route
Dynamic limiter inside, suit for proaudio system
Black-box design, high power small size
Multi current protection and auto reset system
Clip signal indicator
channel PWM running status have led indictor
Suitable for CE approved designs
Proaudio system To Hi-Fi design
SYSTEM TESTING
PROTECTION TESTING
Output shorted testing passed
Shorted output wire while half loader running , , good protection performance.
No loader and amp running . 1vrms and 1khz signal added, shorted output, protect well.
Over load testing passed
Add 1khz signal and connect 2ohm loader, increase the input gain , if loader power over 400W, SMPSOCP protect will happen, it isconstantprotection.
AP testing below
Professional switch power amplifier manufacture,www.csinewave.com
Old 2nd July 2014, 10:16 PM   #38
old tas5630 survived party, tomorow i saw one speaker burnt out and it played all night only on 1 speaker burnt speaker channel was almost short circuit...how is this possible?
edit: i am using sure tas5630 board i thought authlxl was sure employee
Old 3rd July 2014, 03:33 AM   #39
Tas56XX is TI advanced products, circuits better than others single chip class D amp,sound well, even it have bugs sometime, Friends must pay more time and money in it then can use these chip to run well,some time it is complex to make these things perfectly.
From 2007, Sinewave engineers start to develop TAS56XX chip supported class d amplifier.we burnt hundreds of this series chip and finally we make this series amp more and more stable, uploaded modules here are the latest version, we think it is the best solution of Proaudio to Hi-Fi .
Sinewave Electronics Co.ltd have factory and high level audio laboratory.we have rich experiences in class D pro amplifier, especially in CLASS D and SMPS all in one amplifier.these amp have widely used in audio and ultral sonic area , products quality better and better now.
We have list some of our products in DIYAUDIO forums, we got lots of member supports here, base on these good ideas and suggestion we have made rapid expansion .
We will try our best to make more high technology products in this area, thanks for more suggestion from the diyaudio member.
Annonce here, we have no chance to service Sure company now, even we know it is China company too.
How can we make tas5630 as full function amp? authlxl Class D 77 7th February 2012 05:09 AM
TAS5630 damaged when touch the balance input op amp henjoyan Class D 5 16th August 2010 11:29 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
PCB for the Tripath TK2350 2x300W chipset janaf Class D 8 24th October 2004 08:31 PM
Copyright 1999-2017 diyAudio
