New Sure IRS2092 IRFI4020H part # AA-AB32291
Old 16th June 2012, 03:28 PM   #11
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by nigelwright7557 View Post
. . . There are loads of irs2092 based pcbs on ebay.
I've noticed the bad quality 40Mhz Hi-Sincerity 2SD669AC second source fake hitachi device installed on the heatsinks of most ebay IRS2092 based boards. The Sure IRS2092 doesn't use the fake transistor. In the photograph of the Sure is a Toshiba specific 220 casing, such as used for 2SC5171. Can someone tell me what transistor they used?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 20th June 2012, 09:45 PM   #12
exflaco is offline exflaco  Armenia
Daniel, the 669 only for 12v aux dc Ljm l15d l20d l25d no problen with 669
Old 23rd December 2012, 10:44 PM   #13
prasadkj is offline prasadkj
Thumbs up 4-way Active Speaker with IR 2092 Amp
I put together 2 IR 2092 amp board with a mini-dsp. Used a toroid AC 35-0-35 500VA power supply to get +/- 54V DC. Unit works and sound incredible. I will never need to drive this even to 20% of the rated power.
Old 31st March 2014, 09:55 PM   #14
rfj5106 is offline rfj5106  United States
Default Exasperating Ampifier
I have built a power amplifier incorporating the ‘Sure AA-AB32291 Ver.1.0’ amplifier module and it has been totally exasperating to say the least. A picture is posted. I used a 600 watt 40-0-40vac transformer with a 6 X 10K uF capacitors for +56-0-(-56) vdc. There is 0-12vac tap on the transformer that feeds 12vdc power regulator. The 12vdc is used to power the power indicator light and the LED VU meters. The VU meters monitor only the input signal. After he VU meters, the input signal is attenuated by a 50K potentiometer and then the input signal enters the module.
When you power this amplifier on, typically channel ‘b’ is dead, channel ‘a’ is working. Channel ‘a’ if the attenuator is wide open, there is a high pitched whine along with the music. If the attenuator is rolled back 25% (audio taper), the whine very abruptly disappears. If you leave attenuator on channel ‘b’ open and raise the volume on the preamp, at a certain point, channel ‘b’ comes to life very suddenly. There is no high pitched whine as there is channel ‘a’. The other annoying aspect of this amplifier is that it seems to run on the edge of thermal shut down. If the room gets warm, the amp will shut down. So it looks like a small internal fan is advised. But before I buy the fan, can anybody tell me how to: (1) Get rid of the high pitched whine. (2) Get channel ‘b’ working without blowing up the speaker.
When this module is working, the sound is quite acceptable.
Richard Jenkins
Old 31st March 2014, 10:00 PM   #15
You can see a picture of this amp at:
https://docs.google.com/file/d/0B29I...5yT1dyRG8/edit
Richard Jenkins
Old 31st March 2014, 10:10 PM   #16
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Reminds me of the heartache I had when I first started with irs2092 based designs.
I had a whine and it turned out to be noise on the VCC. My regulator wasn't decoupled enough.
I also found I had problems with turn on/off pops thumps and siren type sounds.
IR said I had too much smoothing capacitors. So I put together a small PIC based circuit that holds the 2092 in reset when the VCC drops below 12 volts.
The 2092 is very fussy about pcb layout and decoupling.
The 2092 and the mosfets need very close decoupling.
I also had to fiddle with the over current setting resistors to stop resetting on high volumes.
I wanted to get to high powers so I used irfb4227's with gate driver transistor buffers.
The 2092 driver output is quite weak and just about manages to cope with a pair of irfb4019's.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 3rd April 2014, 10:47 PM   #17
Jsixis is offline Jsixis  United States
Originally Posted by redjr View Post
I just purchased this same amp module (Sure IRS2092). I intend to power it so that I get the maximum output of 100wpc into 8 ohms. My question is; Can I build a simple, well filtered linear PSU that will supply ~56VDC/rail to power this thing? Or, do Class D amps need to use a SMPS?
yes you can use a linear supply, it may sound better.
I know nothing, so learning is really awesome.
Old 4th April 2014, 01:01 AM   #18
While the spec sheet says 56 volts, I am not sure as my amp has a 56 volt (40vac-0-40vac transformer) supply and one channel does not want to start unless the preamp is turned way up, then it kicks in. Weird. I suspect the 56 volts is not enough to get the module started.
Richard Jenkins
Old 4th April 2014, 01:10 AM   #19
arlis is offline arlis  United States
I have one that's getting 60.3 volts and it works just fine.
Old 21st August 2014, 08:47 PM   #20
silent mike is offline silent mike  Canada
I have this board + Connex SMPS500QRv2 power supply (64V + & - in actual use). After a week of initial troubles, it's finally working AOK, and sound quality is excellent, as is the power. It's all running atop my desk right now; l am planning to house it in a nice aluminum case & bridge the amp's heatsink to the 8mm thick front panel for cooling.
Here's my issue: The voltage gain of this amp is 40 dB -- way too high for most home audio gear. I'd like to reduce it to around 26~30 dB. Anyone know how to do this?
This guy, Larry, talks of changing R7 from 3k to 6.2k on Sure AA-AB32321 version of the same amp, but it's not clear which one is R7 and whether AA-AB32291 uses the same input circuit? Larrys Corner: Class D Audio amplifier - IRS2092S
New Sure IRS2092 IRFI4020H part # AA-AB32291Hide this!Advertise here!
My design L20D IRS2092+IRFI4020H 200W8R ljm_ljm Class D 1048 22nd September 2017 05:37 PM
Need part # for 30-pin connector part inside Logitech Transporter on front panel PCB Bellatone Digital Source 4 27th April 2011 07:39 PM
Heathkit AA-40 or AA-121 panheadchopper Tubes / Valves 1 5th February 2011 03:51 AM
FS: HIGH END Home Audio lot..Opera Louspeakers, Triangle Comete, AA Primo, AA, etc. JiggaD369 Swap Meet 6 22nd August 2008 01:32 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 05:45 AM
Copyright ©1999-2017 diyAudio
