Go Back   Home > Forums > Amplifiers > Class D
Old 28th December 2011, 10:15 PM   #1
nigelwright7557's Avatar
Default The dreaded irs2092 clicking on output.
I took the application sheet circuit for my 2092 amp.
I built a few with no problems.
Now all of a sudden the last 3 I have built arent working properly.
The music works fine up until about 90% max volume then the sound breaks up with the 2092 resetting.
The circuit looks pretty sound to me.
I have tried adjusting OCSET and CSH to give max current but it doesnt make any difference. Added extra decoupling and tried larger electrolytics where they are used and no joy.
Even tried larger output coil and different filter components.
Any suggestions would be gratefully recieved.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 28th December 2011, 10:51 PM   #2
I found the problem, I use irfb4227 mosfets and the 2092 wont drive hard them without clicking.
Old 28th December 2011, 10:52 PM   #3
elevator's Avatar
Originally Posted by nigelwright7557 View Post
... then the sound breaks up with the 2092 resetting.
Can you elaborate on this symptom?
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 28th December 2011, 10:56 PM   #4
The irs2092 resets and you can here the music click in and out as it resets and starts again.
It looks like the mosfets werent switching on fast enough as the 2092 cant drive irfb4227's very well.
Tried a second pcb and that had the same problem and was fixed by adding tc4420 drivers.
I noticed that reducing the mosfet gate driver resistor that the problem wasnt quite as bad, again pointing to mosfet gate drive problems.
Old 28th December 2011, 11:56 PM   #5
The pcb with problems are using a new batch of irfb4227's. Could be this batch are more capacitive on the gate.
Anyhow adding the buffer sorted it.
Old 29th December 2011, 09:09 AM   #6
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
that would be interesting to know, if there was difference between fets alone
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
IRS2092 How to drive more then one pair of output transistors? RealForce Class D 30 27th April 2010 05:49 PM
Fixing the dreaded power up/down thump! paulspencer Everything Else 0 29th March 2010 12:52 AM
The dreaded impedance thingie.... Lostcause Everything Else 23 22nd July 2006 12:08 PM
the dreaded c word....(crossovers) xstephanx Full Range 6 19th June 2006 02:55 PM
Pioneer SX-838 -- random no sound output, clicking relay VTbimmer Solid State 11 26th February 2004 12:12 AM
Page generated in 0.08613 seconds (72.91% PHP - 27.09% MySQL) with 10 queries
