Go Back   Home > Forums > Amplifiers > Class D
Old 17th December 2011, 03:42 PM   #1
Default Help needed with irs2092 amp
I'm building amp based on iraudamp7d reference design. I made new PCB layout, but almost same as iraudamp7d. Today I soldered it to the stage, to just test the irs2092. No output mosfets, no OCP. Only thing I managed to do is kill the irs2092. On the both output is -40V. Could someone check the PCB?
What should I check? I have a osciloscope to.
Does anyone have a tested simple as possible PCB that I could try?
Old 18th December 2011, 11:58 PM   #2
nigelwright7557's Avatar
All you can do is go back and check your schematic for errors.
Personally I wouldnt have powered it up without the mosfets.
The amp requires feedback to oscillate.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 19th December 2011, 06:13 AM   #3
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
why didn't you use fets? you can solder everything on, and just don't connect main voltage... you can provide +/-5 for the IRS and about 12v for IRS gate drive
And if that all is good, you can use main voltage... you can even ramp it up slowly from +/-0v to +/- what even you have for your supply, it you can get your hands on adjustable supply, not some trafo or smps
I would never not use fets when powering up IRS
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Class-D Amp with IRS2092 mag Class D 185 24th February 2012 03:35 PM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
Page generated in 0.07373 seconds (70.21% PHP - 29.79% MySQL) with 11 queries
