| Class D Switching Power Amplifiers and Power D/A conversion |
hello,can someone please help me with a clip limiter circuit
thank you
#2 |
hi.
do you mean a clip indicator or a audio limiter to lower the input signal? |
#3 |
hello,i mean a limiter to lower the input signal
#4 |
hi.
i dont have any schematic of a limiter who works well. but i have used the clip indicator from ESP project23 it works great. |
#5 |
Me too, but this is not limiter, but good way to start if nothing else
#6 |
I used a resistor with two zener diodes to limit the input voltage
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#7 |
Some pro amplifiers use LM13700 transconductance op-amps for variable input attenuation. The LM13700 is normally off. Consider getting some schematics and study how this is implemented. You can start by looking at Behringer EP2500 schematic, a well known one. Then you can study others from QSC, Yorkville, etc...
An alternative to LM13700 are light dependent resistors (LDR) and "Vactrols".
I use to feel like the small child in The Emperor's New Clothes tale
#8 |
You could work on the amplitude of the triangle wave, increasing it to clip less. (assuming your design is clocked)
You don't need a weatherman to know which way the wind blows --Bob Dylan |
#9 |
hi
greetings there is a working limiter with pcb on solid state thread on page 8 vertex amp thread page 7 post 61 using ic LM13600 LM 13700 also can be used qsc uses this circuit only mods are instead of 1.2k resistor 1k prest can be used to limit voltage to 1.5 volts hope this helps warm regards andrew lebon |
#10 |
Thanks guys,especially Eva
I found the vertex amp thread and i found the LM13700 on local part's shop in Romania (i think that LM13700 in the vertex circuit work as a compressor to) Thank You |
| amp goes clip | sberube | Multi-Way | 2 | 15th February 2005 12:22 AM |
| What's wrong with this clip? | roibm | Music | 0 | 6th November 2004 12:01 AM |
| How does clip protection work? | Pbassred | Solid State | 13 | 24th May 2004 06:22 PM |
| songs which cause your amps to clip | perfusionist | Solid State | 10 | 17th May 2004 11:27 AM |
| Page generated in 0.09737 seconds (79.63% PHP - 20.37% MySQL) with 10 queries |
