Problem with IRS2092 Deadtime
Old 14th December 2011, 08:23 PM   #1
fanmade is offline fanmade  Austria
Default Problem with IRS2092 Deadtime
Hi all,
I'm working on a 300W Class-D amp with IRS2092 and IRFB4227.
Should deliver up to 300W stereo. The FETs where driven by a BJT totem pole and the amp sounds fairly good.
Theres just one problem: The MOSFETs getting hotter than they should in idle mode.
The Pics show more:
(1) CH1 Low Side Gate Signal CH2 Drain Low Side Rising Edge
(2) CH1 Low Side Gate Signal CH2 Drain Low Side Falling Edge
(3) CH1 High Side Gate Signal CH2 Low Side Gate Signal Rising Edge
(4) CH1 High Side Gate CH2 Low Side Gate Falling Edge
(5) PWM Output Signal Idle (250kHz)
All referenced to -B
In (4) the High Side Gate have enought dead time but in (3) the it isn't enought and causes shoot through.
It seem's the DT isn't symmetrical on High and Low side of the IRS, I dont know what to do because already using max setting(105ns)
Supply is +-40V
thank you for help
Old 14th December 2011, 09:18 PM   #2
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Originally Posted by fanmade View Post
Hi all,
The Pics show more:
Supply is +-40V
thank you for help
I would make a different gatedrive circuit, you have some nice drivertransistors and then you add 4R7 in series with both turn on and off.
Why not try and make you gatedrive a little different, start maybe with a 1N4148 in parallel with 4R7 to make turn off faster than turn on?
A base resistor in you gatedrive transistors might also be worth it ;-)
Best regards
\\\Jens
Old 14th December 2011, 10:14 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The deadtime on the 2092 works fine so it has got to be your driver that is the problem.
I use a TC4420 driver chip and it works with upto 2 pairs of IRB4227.
I also use 10R gate resistors.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 15th December 2011, 01:00 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The gate drive buffers need base resistors to control reverse behavior of the NPN/PNP when di/dt spikes show up at the gate (through Ld) and drive it temporarily outside the gate drive rails. Also, some resistive drive impedance is needed at high frequencies to damp potential layout resonances (MOS based gate driver outputs are resistive but always have capacitance and body diodes to the rails).
Speed up turn off with diodes and optional resistors as recommended, turn off di/dt must always be higher than turn-on di/dt to avoid "regenerative" cross-conduction during any overlap condition in switching. Don't make it faster than needed, gate drive "commands" EMI production. EDIT: IRFB4227 has 2.2 ohm of built in gate resistance, with a good layout it may not need more, just the diode.
(1) and (2) show cross-conduction further helped by the 20ns/50Mhz resonance. This resonance should be damped with RC(L) for optimum performance and minimum interference between channels. It's d-s capacitance of the MOSFET that is turned off (240pf typ. for IRFB4227) resonating with all the parasitic inductances that close the loop (TO-220 leads typ 12nH d-s, PCB tracks, supply capacitors typ 1nH per mm of lead spacing).
I use to feel like the small child in The Emperor's New Clothes tale
Old 15th December 2011, 06:24 AM   #5
luka is offline luka  Slovenia
luka's Avatar
I would also use different gate drivers, something like ZXGD3002E6, and resistor to this driver from IRS, 18v zeners are not really needed
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 15th December 2011, 11:58 AM   #6
@Eva
OK i will add Base Resistors and Speed Up turn-off diodes, lets see if it improves switching timing.
Where i have to add the damping RC network because of the cross-conduction resonances?
Are the 1n 10R at the PWM Output bad dimensioned?
@luka
The ZXGD3002E6 look very nice, I think i will test it in a new desing later.
Old 15th December 2011, 09:31 PM   #7
luka's Avatar
@luka
Oh and VERY cheap
I FEEL SLOVENIA
Old 15th December 2011, 09:34 PM   #8
[QUOTE=fanmade;2821499@luka
The ZXGD3002E6 look very nice, I think i will test it in a new desing later.[/QUOTE]
The TC4420 costs a little more but is available in through hole.
Old 15th December 2011, 09:40 PM   #9
luka's Avatar
how much would be a little more?
and smd is good, very small footprint, it takes no more then smd resistor, also faster then tc
I FEEL SLOVENIA
Old 15th December 2011, 09:44 PM   #10
86p its a larger package so should dissipate a bit more power.
I use them for driving 2 pairs of irb4227.
Problem with IRS2092 DeadtimeHide this!Advertise here!
IRS2092 with IRFB4227 problem! tantal.lpt Class D 72 22nd June 2017 09:29 PM
Problem Osc. Frequency - IRS2092 and IRFB4227 nikigada Class D 29 12th September 2011 10:46 PM
Yet another IRS2092 problem LukeFrog Class D 40 7th June 2011 09:57 PM
Best Deadtime Delay Circuit in Class-D Workhorse Class D 28 20th April 2007 04:35 PM
Measuring deadtime Brian Oppegaard Class D 39 21st July 2005 08:23 AM
Copyright ©1999-2017 diyAudio
