| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
Have you seen this:
eBay: YAMAHA YDA148 2 X 30W @ 4ohm Class D Amp TA2024 killer |
#12 |
Thanks for posting. To me that ebay item is BS. Kind of like those "1000 watt quad channel" car stereo amps you find in a flea market, that when taken apart reveals a single 20 watt amp chip, with all 4 inputs and outputs joined. The chip is not rated by the manufacturer for that power rating, so its an exaggeration . Who wants to buy from anyone that lies about technical specs.
Plus, for the small convenience you get for having terminal screws over solder connections, is not worth paying 3X more. this link still has the best deal I've seen on a YDA148 based amp, under $10! Y148 Audio Amplifier Module on Geminideal.com |
#13 |
They are the same specs. Just wondering how good or bad is this amp.
The board I posted I found out yesterday and seems much like this one Goodfortune/ºÃÔËÀ´R7¹¦·Å»ú YDA148 30W*2 ·¢ÉÕ¹¦·Å°å-µçÄÔÓ²¼þ/Öܱß/ÍøÂçÉ豸-µçÄÔ¶àýÌåÒôÏä | Íø¹º-ÅÄÅÄÍø which is also at dx electronics. |
#14 |
Just ordered this amp from deal extreme, plan to make a desk top mini MLTL with small FR's
#15 |
#16 |
Hey thanks for this tip, I will definitely do this. What's caps are the best to use? Are there any other weak components that cd be upgraded at the same time
#17 |
I also changed the small aluminum caps with some nichicons same value from the told series, but not much improvement, a little more detail n highs, also maybe changing the inductors with some wurth, but this haven't try yet, someday I might... But changing the 2200uf CAP for a 4700uf one made the biggest improvement..
#18 |
Ok I will just try the one mod for now, how about a Mundorf M-lytic 4700uf 50v?
EDIT - bit expensive .. will go for a Nichicon http://www.hificollective.co.uk/comp...chicon_fg.html is 16V ok? Last edited by Bill poster; 28th January 2013 at 09:36 AM. |
#19 | |
#20 |
Hifi collective in the UK seems good
, how important is cap voltage? sorry for the questions
| B&W ASW 675 amp module repair | soerboe | Class D | 2 | 19th October 2011 06:56 AM |
| Endangered Audio - Gristleizer Module & New Module Line! | endangeredaudio | Vendor's Bazaar | 0 | 5th March 2010 03:03 PM |
| What amp module is this? | MikeHunt79 | Class D | 14 | 13th June 2009 11:39 PM |
| Please Help, replacing amp module in Yamaha power amp | priscared | Solid State | 5 | 30th June 2004 04:04 AM |
| Corcom entry module w/switch & ac filter & fused. | KevinLee | Swap Meet | 8 | 9th December 2003 10:40 PM |
