| Class D Switching Power Amplifiers and Power D/A conversion |
Can I run two UCD 180 modules off of one Meanwell S-350-48 SMPS?
As numbers imply, it is 350VA and 48 DC volts, a good input voltage for the UCD 180. Second question would be, what do I run into the the ground input of the UCD 180? Do I connect the Meanwell ground to the input ground of the UCD 180, or do I ground the UCD 180 to a chassis ground? |
#2 |
first of all. is it 48VDC, +/-48VDC or +/-24VDC?
soon to be: papa's Class A all the way
#3 |
+/- 48VDC
#4 |
...and with three terminals each of -/+ 48VDC outputs, but just one ground terminal.
#5 |
I also have a robust 650VA transformer that is made for hypex modules and a Hypex power supply module, but I do not have a soft start. it will not be here for two weeks.
I wanted to see how the SMPS would sound. I could go with the linear supply, but without a softstart do i risk blowing the amp modules? |
#6 |
most UcD build run GND direkt from amp module to PSU.
you will not blow your amp without softstart. but maybe you will blow your main fuse on startup.
#7 |
dtaylo
On the specification it is called Single Output .... so I do not think it is a +- SMPS .... the ground is for the input, Ground and not common ..... ... http://www.meanwell.com/search/s-350/s-350-spec.pdf /Baldin |
#8 |
yes. these seems to be singel 48VDC.
#9 |
I will stick with the linear supply. Thanks for the responses.
#10 |
remember the softstart
or you will sit in the dark
| Pair of TK2050 amps with matching 27 volt Meanwell Smps | bigaudioscotto | Swap Meet | 3 | 25th January 2011 05:19 PM |
| Meanwell SMPS and LM3886? | THUMP LUMP | Chip Amps | 63 | 25th November 2010 10:38 PM |
| Meanwell 12V and 24V power supplies SMPS | boywonder | Swap Meet | 2 | 21st September 2010 01:56 AM |
| SMPS Meanwell S-250-24 (24V-10A) [20€+ship] | madqwerty | Swap Meet | 1 | 19th September 2009 10:25 AM |
| using meanwell SMPS S-350 as power amp PSU? | lhgin | Power Supplies | 2 | 18th August 2009 10:36 AM |
| Page generated in 0.09686 seconds (76.19% PHP - 23.81% MySQL) with 10 queries |
