Go Back   Home > Forums > Amplifiers > Class D
Old 4th December 2011, 10:45 AM   #1
Default switching toroids heating up too much.
hi there.
i am using CLASS--D lanzar vibe 3.5KD amp 700 winto 4 ohm for powering my 12 inh 20 hz tuned subwoofer crossed over at 50 Hz with a 20 Hz subsonic filter.
Now this is a car amp and i am using in HT so it is powered with Lambda EWS-1500 -12 , 1500 watt , 12 V SMPS, 125 A and sure its a big thing.
Now even without no signall at the amp input, the switching transformers get very hot and so do the filtering chokes but the FETs are not at all hot. My question is could it be due to EMI present in SMPS ????? is it a bad combination.??
Old 4th December 2011, 11:32 AM   #2
Did it Himself
richie00boy's Avatar
Is the load connected while you are doing this test?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th December 2011, 11:35 AM   #3
darkfenriz's Avatar
How hot?
30-40 degrees celsius over ambient can be considered normal by some designers.
Old 4th December 2011, 02:12 PM   #4
No. even with load removed its get hot. like 30-40. but not on clean car DC supply i remmebr. but strangely the power FET and heat sink are cool cucumber on no load. its just the TWO toroid switiching transformers and filtering toroid coils. BTW its a switching class D MOSFET regulated AMP. My sixth sense is pointing 100-200KHZ pulses getting the way in torioids and their cancellation causing heating up of ferrites?????
Old 5th December 2011, 01:33 AM   #5
nigelwright7557's Avatar
I use a t106-2 core with 18SWG enammelled copepr wire and it barely gets warm.
I originally used power cores but these got to 120 degrees !!!
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
An amplifier without any heating badboy6120 Class D 21 13th August 2011 09:58 PM
heating of mosfets takku Solid State 3 2nd April 2010 08:31 PM
Heating the circuit? lumanauw Solid State 2 31st December 2006 05:44 AM
heating kathodyne Tubes / Valves 3 2nd September 2005 12:49 PM
Page generated in 0.07153 seconds (72.10% PHP - 27.90% MySQL) with 10 queries
