| Class D Switching Power Amplifiers and Power D/A conversion |
With respect to the discussion about clocked designs vs self oscillating designs, I put together some fundamental thoughts and examinations.
The notes include multiple graphics, so I put all in one pdf. ![]() ![]() Well, after being rejected by the diyaudio upload system I had to split it in multiple documents... sorry for that. ![]() ![]() The notes are intended as a new starting point for discussion. Comments, experiences, comparisons and examinations are highly welcome. |
#2 |
Hi Choco
Very interesting. I think our ears and brain do not sum like the two resistors. That is why you dont hear it. I think that beating must be shown in both signals, i.e. like a 2 kHz signal in either of the outputs, for the ear to hear. I therefore think that the beating signal must be injected into the other chanel to be heard, either through the PSU, air or other. Could you post the LTSpice file for further experiments? Best regards Baldin
#3 |
Hi Markus
Interesting. The beep cannot be anything else than effect of AM demodulation which took place somewhere (I'd suspect generators if I were to guess). A sum of two sines of different frequency should simply add up according to superposition prinicple, and so do the spectra of them creating something identical to AM signal of a given carrier and 1kHz modulation. It's just two supersonic fourier components . Remember it only takes one diode to demodulate AM signal and 2kHz is in the best hearable frequency range. The only intriguing issue is your "uncertain perception that there might be something." That's what you get close to upper hearing range. I did myself a generator testing of what I really can hear and around 19kHz I was sure I was hearing the tone. But at 20.5kHz I got something like what you've described, that was not a hearable beep of any sort, but a dizzy feeling. I ask my friend to switch on and off the generator and although I didn't experience pure kind of hearing, I seemed to have known perfectly if a generator is on or off. Possibly also (little speculating here) the so-called 'binaural beating' is doing some tricks. It is a very puzzling brainf\/cking experience well in audible range, because it triggers the same parts of brain, which are responsible for sensing direction of the incoming noise (phase comparison, sensing the Doppler effect). I wouldn't be very much shocked if it worked a bit over the real hearing threshold. Regards, Adam Last edited by darkfenriz; 4th December 2011 at 08:33 AM. |
#4 |
Interesting topic. can help us reflect on some things. I would like to add something to the last questions at the end of the pdf In the case of two ultrasonic frequencies (2KHz with a difference), sent to two speakers. We can close one ear and hear perfectly the beep. This shows that: 1) The difference is not produced (as a result) of our brain. 2) Our two ears are actually two independent channels, and our brain does not use for differences in frequencies but in amplitude and delay. Regards Last edited by AP2; 4th December 2011 at 08:45 AM. |
#5 | |
I disagree- just rechecked right now. In this case I do not hear anything, no matter if one ear is closed or not. |
#6 |
Hi Adam,
yes I also think, that it must be sort of a demodulation effect. Because the beating signal itself does not look like being audibile. Besides your fourier description, we could also describe it as one ultrasonic signal which grow and disappear, just the envelope would be in the audible frequency range (==> that' what we see on the scope.) Hi Baldin, I am attaching the LT Spice file. It should run with the standard libraries. The buffered transmission line is not mandatory to get the beating, but reflecting real world a little better. |
#7 |
One more examination:
Examination 5: Two signal generators, two ultrasonic frequencies, difference around 2kHz. Both signal generators have the ground connected (like all previous examinations). Now the tweeter is connected between both hot ends, like in a bridged amp. ==> Strong 'beeeeeepp' again... This might be an indicator that bridged configurations of selfresonant topologies are more critical than unbridged. |
#8 |
#9 |
Do I hear a beat frequency between your two messages?
You don't need a weatherman to know which way the wind blows --Bob Dylan |
#10 | |||
| clock, master/slave no clock? | pforeman | Digital Source | 0 | 29th January 2011 06:17 PM |
| My CD Clock - the "Kwok Clock" | kwokm | Digital Source | 13 | 10th September 2006 12:34 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 07:18 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 01:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 01:20 PM |
| Page generated in 0.12829 seconds (79.85% PHP - 20.15% MySQL) with 11 queries |
