Go Back   Home > Forums > Amplifiers > Class D
Old 29th November 2011, 06:20 AM   #1
Default Topping TP30 (Tripath) with Battery & Automatic Charger
I'm going to get a Topping TP30 amp. Actually, I ordered one from China but it never came, so I have to look for a better source.
I've already got a pair of 200 AH golf cart batteries wired for 12V hooked up to a 30A Samlex automatic charger that I use as a UPS.
Could I run the TP30 amp off the batteries with the automatic charger? Or would the voltage variance with the charger cause any problems?
What do other people running the Tripaths off batteries do about charging? Do they keep a charger hooked up all the time, or only in-between listening?
Thanks.
Old 29th November 2011, 03:34 PM   #2
panda360's Avatar
Try this one. Sistor company of Taobao.
Remember do not pay your money directly to seller.
Wholesale Topping TP30 - Buy Low Price Topping TP30 Lots on Aliexpress.com
Old 29th November 2011, 04:04 PM   #3
Saturnus's Avatar
Thanks.
Buy a much smaller charger, or a 10-15W solar panel. The amp only uses about 350mA at full power output so you got 23 days playing time on that battery, at max volume 24/7. So all you need is a tiny trickle charger to keep it topped off between listening sessions.
Old 30th November 2011, 03:20 AM   #4
Thanks. I ended up just ordering one from Amazon/Parts Express. It's more expensive but at least I have a good chance of actually receiving it. I paid via paypal for the first one from China, so I was able to get a refund.
I already use the batteries and charger as a UPS for my computer system, too, so it would be doing double duty. But it sounds like it might be too risky without a DC-DC voltage regulator.
Old 30th November 2011, 01:52 PM   #5
Thanks.
I would strongly recommend in your case to charge the battery full and then disconnect from charger. 200 Ah battery and 30 Ampere charger sounds to me needless to go a risk because you easily can listen weeks with one charge cycle. After some days operation I would just check up battery voltage without load. Under 12,2 V I would recharge full again.
Battery Charger broke my Class D amp? johnviera Class D 17 24th September 2011 01:32 AM
Topping TP30 -- Add Subwoofer? OPTiK Class D 0 17th April 2011 05:59 PM
I got my Topping TP30 today... MyNameIsJake Class D 2 5th April 2011 05:49 AM
T-amp battery power with charger tinitus Class D 0 8th April 2010 03:05 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
Page generated in 0.10334 seconds (74.29% PHP - 25.71% MySQL) with 10 queries
