Go Back   Home > Forums > Amplifiers > Class D
Old 26th November 2011, 10:04 PM   #1
Default The SMPS300R is 110V - any problem using with 117V and 120V?
After reading comments here am considering buying Hifimediy T4 or T2 amp.
But, the power in my house is the more standard 117 )or 120VAC=, not the uncommon 110V. This power supply is designed for 110 vac. 110 vac is really not common, why would they design a power supply for this voltage?
What are the implications? Overheating? Shorter life?
Also, what other parts are needed to put this together? A dual audio potentiometer? What value and where to buy it?
Old 27th November 2011, 12:32 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
It'll be fine. Almost every "110V" SMPS on the planet can handle 100-130V.
Old 27th November 2011, 01:19 PM   #3
KatieandDad's Avatar
ALL SMPS designs are PWM controlled. A few extra volts wont normally worry them.
If a designer has produced a design that cannot cope with a few extra volts then he/she should be crucified.
Most PSUs can operate between 110 and 240V but that takes careful design.
Old 27th November 2011, 01:40 PM   #4
As Gmarsh says, most SMPS are designed for universal use around the world.
The SMPS will specify the range of voltage for which it is suitable.
If it does not state that usable voltage, then don't plug it in. Send it back and demand all your money back.
regards Andrew T.
ok, power supply question, 230v - 117v conversion aardvarkash10 Tubes / Valves 6 21st July 2009 01:11 PM
1500VA power transformers 120V:120V RyanW Swap Meet 4 17th February 2009 08:31 PM
117v heater tube 117n7 AtomiKM Tubes / Valves 3 12th December 2006 03:24 AM
120V AC to 120V DC, 10A hawkfeather Power Supplies 7 30th December 2005 08:02 AM
Page generated in 0.07183 seconds (72.17% PHP - 27.83% MySQL) with 10 queries
