| Class D Switching Power Amplifiers and Power D/A conversion |
Hello diyaudio!
i am a new member here, also my first thread, but i have been looking in the forum for some time now. especially in the "class D amp" section. i am going to build a boombox for outdoor purpose. my demands of this boombox is high volume(db), small volume(m3) and a decent battery life. since i am a student without infinite funds, it has to be cheap too! the build will be like the Boominator, just in miniature and a bit smarter design(if you ask me). this is what i have found so far; Sub/mid: Fane sovereign 100w 6" Impedans: 8 ohm Effekttålighet: 100W RMS Frekvensomfång: 103 Hz-6 kHz Känslighet: 94,7 dB Magnetvikt: 20 oz Talspolediam: 1,50" fs 111 Hz Re 6,7 ohm Le 0,55 mH Qes 0,49 Qms 9,75 Qts 0,47 Vas 4,49 liter Cms 0,2 mm/N Bl 9,8 T-M Mms 10,3 gram Xmax 1,8 mm Sd 126,7 cm² Xmek 5,0 mm tweeter: Rila SA 38 Piezo Märkeffekt: 150 W Frekvensomfång: 2000-20000 Hz Distorsion vid 105 dB: Mindre än 1% Vikt: 0.064 Kg Känslighet (1m, 1W): 91 dB the Piezo and sub are shopped from HIFI KIT ELECTRONIC AB - Högtalarelement HiFi Hembio Billjud/Marin Studio PA/DJ Kablage Tillbehör the cheapest Ta2020 amp from UK ebay : TA2020 PCB 25Watt Tripath Class-T Audio Amplifier Board | eBay and then some switches and batteries. here are some quick sketchup pictures of how i want it to look like: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() the white cube is 1x1x1m! The plan is that there will be 2 cabinets with 2 magnet-to-magnet subs. there will be 1 basshole(dont know what they are called) in each cabinet. in the trapez on top, all the electronic will be suited. i think the ends where the tweeters are, there will be space for 1-2 RC/custom made battery packs in each side. in the middle there will be room for placing an ipod/mp3. my plan was that there would be a 12v DC out and RCA out in the middle. then the on/off switches, the fuse/circuit breaker and the amp with volume control would be placed next to the room for mp3s. my idea is to keep it simple, so i want to make the circuit like this: ![]() ![]() this is my first boombox so please comment on it! i know that there are some pros out there! thanks Duch3n Last edited by duch3n; 21st November 2011 at 07:08 PM. |
#2 | |
You might want to read the Boominator thread as to why it can't work. Back to the drawing board. Good luck. |
#3 |
can you please tell me on wich page to look? i have read the first 10(maybe not good enough)
or maybe give me a hint why it wont work? |
#4 |
The Boominator thread is 2414 posts long. You really expect me to remember where anything is described in detail?
Anyways, the drivers and the cabinet size you have chosen will dictate a bass response on par with or maybe even slightly worse than the average mobile phone in loudspeaker mode. |
#5 |
so you suggest that i should build it bigger, and then loose some mobility?
i remember that you wrote that going below 80-100 Hz would be a waste for outside use, the drivers goes down to 103, so i dont think there would be a problem there. besides, the woofers/phone speakers have a higher sensivity(3,7db + ½-1 because of the magnet to magnet system) than the tweeters så there is a "natural" boost in the low frequencies. dont you think the 6" would be able to handle it fairly? i appreciate your help a lot, you are one of the pros i were talking about! |
#6 |
wow . I pod and class D had given a second life to the ghettoblaster
in the new millenium ![]() ![]() ![]()
#7 | |
You just can't break the laws of physics, on an every day basis. The Boominator is the smallest possible cabinet you can possible ever design when you consider how low it goes in the bass, how loud it can play, and how little battery it uses. |
#8 |
Banned
" there will be 1 basshole(dont know what they are called) in each cabinet."
lol @ basshole. |
#9 |
you are probably right! the cabinet sizes are acutally calculated cabinets though(with minor changes).
how big/small woofers do you suggest the woofers should be? and do you know any good way(an online calculator maybe) to figure out the exact measurements of the cabinet? It seems like the one i found on google is worse than nothing! |
#10 |
Read this: It's for a minimalistic boombox design with driver recommendations, crossover instructions and everything else (more or less)
Monacor SPH-30 - Speakerplans.com Forums - Page 1 |
| DIY Boombox in a suitcase! | Veloxy | Multi-Way | 9 | 19th November 2011 10:58 PM |
| DIY boombox | Scarbwill | Class D | 1 | 8th September 2011 03:31 PM |
| DIY Boombox | happyb | Multi-Way | 4 | 27th March 2008 08:30 AM |
| DIY Boombox Worklog and Partlist | navinjohnson | Everything Else | 5 | 5th December 2007 12:27 AM |
| Page generated in 0.14855 seconds (73.43% PHP - 26.57% MySQL) with 10 queries |
