| Class D Switching Power Amplifiers and Power D/A conversion |
First sorry for my English... I got some problem with my Directed D2400 amp and I can't find a way to fix it. When power's up, green led stays on, not going into protection mode, but no output. I have checked the power supply, it's OK, at the middle pin of the rectifiers I got +-60 V, at the 640 and the 9640 output banks i got leg 1 - 59.9V , leg 2 -0 V, leg 3 - 59.9, on both sides of the amp, they seems to be OK. Any other idea? |
#2 |
I would check the mosfets for a short D-S.
Other than that could be the class d chip has gone. Alos check G-S for shorts, I have found that fault a couple of times.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
I don't have found any short's but, i have taked out all of them and checked piece by piece, by charging them with a multimeter and discharging with my finger, and a irf640 and a irf9640 doesn't hold the charge (or they doesn't charge up). I think this is the problem. What do U think about?
#4 |
When mosfets blow they usually go short S-D.
I have seen short G-S a couple of times. I have never tried to charge one up. Apply a sine wave to the amp and see where the signal stops.
#5 |
I have replaced them, but still nothing. No output. I got 2x TIP41C and 2xTIP42C transistors, what are getting hot in very short time, but I have taked out, and they are ok. There is also 2x 2,2Kohm 3W resistor what also gettin hot very quickly. They are marked with red. On the pictures is missing a capacitator (I put it back, it's OK), and the 2x TIP41C transistors. Any suggestions where I can continue my project?
#6 |
Somebody got a schematic for this kind of amp? I think it's the same board what the Brutus 1200 amplifier uses. Thank you in advice
#7 |
I have found 2 pairs of faulty transistors on the driver board. Somebody can help me to identify them? One of them is DK QQ - I got 2SC4672 for them but I can't find anything for AG QN. Any idea?
| Directed D2400 | mike49504 | Car Audio | 5 | 22nd September 2011 04:40 AM |
| directed D2400 | mike49504 | Car Audio | 11 | 29th August 2011 01:55 AM |
| Directed D2400 | mike49504 | Car Audio | 5 | 26th July 2011 03:25 AM |
| directed d2400 | mike49504 | Car Audio | 17 | 24th August 2010 12:23 AM |
| Directed D2400 | mike49504 | Car Audio | 10 | 20th April 2010 04:52 AM |
| Page generated in 0.09132 seconds (71.92% PHP - 28.08% MySQL) with 11 queries |
