Go Back   Home > Forums > Amplifiers > Class D
Old 31st October 2011, 09:48 AM   #1
navnee4 is offline navnee4  India
Default CLASS D GROUNDED AMPLFIIER
HI ALL
Can the use the attached toplogy for grounded amplifiers
thanks in advance
Naveen Kumar P
Old 1st November 2011, 09:16 AM   #2
baga is offline baga  Romania
Yes, because the transformer isolates the output stage from the mains. You can put that ground anywhere in the output stage. BUT , if you don-t isolate the input from inverter or the driver, you must not ground the input from the inverter or any device connected to the input.
Old 1st November 2011, 09:44 AM   #3
Default thanqu
hi
thanks for ur reply
i am experimenting now of power level 40kva
regards
naveen
Old 1st November 2011, 12:31 PM   #4
Pafi is offline Pafi  Hungary
Interesting. Somebody who wants to build such a huge device asks such a basic question?
(And with a conventional transformer, instead of SMPS?)
BTW: why is that stage called "unipolar"?
Old 1st November 2011, 06:34 PM   #5
' i have already build class D for BTL upto 70KVA
now my requirement of class D is grounded shaker i thought i can use the same by isolating
since my input is 415V,3Ph (india) i have to step down my voltage for the selection of MOSFETs @ that particular current rating.
UNIPOLAR is a type of PWM technique used for BTL type Class D PAs
Old 1st November 2011, 09:22 PM   #6
this circuit at times gives shock
Old 2nd November 2011, 09:18 AM   #7
Pafi is right, if you work with that voltage and power, you must know that things, otherwise you can take an electrical shock or that thing can explode in your face.. TAKE CARE.
What mosfets are you using for that power ?
Old 4th November 2011, 06:39 PM   #8
fredos is offline fredos  Canada
I use this topology for over 10 years in my D-Amp HVI series. Work well and stable, but you need to use post filter feedback. No need for the 2 cap and resistor that go to V-. Just make sure that you add voltage divider from PSU to front stage to keep each leg of bridge at 1/2 Vcc.
Old 5th November 2011, 04:45 AM   #9
THANKS fredos for your suggestion
i appreciate your point of voltage divider technique which is impressive and i will implement it.
I am taking feedback before filter but it is not effective for compensating dead time so i have added cap and resistor to V-. My PWM is uniplor PWM
please suggest for dead time compensation and feddback technique
Old 5th November 2011, 04:47 AM   #10
HI BAGA
I am using 48Amps 500V MOSFETs which are paralleled for required power
5842 grounded grid alexg Tubes / Valves 19 27th April 2007 11:49 PM
Grounded Grid jswen Tubes / Valves 0 17th May 2006 11:48 PM
Grounded Grid Help gelder Tubes / Valves 8 11th December 2005 02:00 AM
Staying grounded superscrub Car Audio 9 29th August 2005 06:48 PM
grounded bridge Opie Solid State 1 7th February 2002 12:13 PM
Page generated in 0.11107 seconds (87.73% PHP - 12.27% MySQL) with 11 queries
