Full-bridge vs half-bridge Class D amplifier? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th October 2011, 05:02 PM   #11
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Originally Posted by eem2am View Post
I would have thought that if you are supplying a Class D amplifier with an SMPS.....then it would be far better to make the Class D amplifier a Full Bridge Class D amplifier?
..because it makes the supplying SMPS much simpler in that it only has a single rail output.
Also, unless the audio power is very very low , a full-bridge class D amplifier is cheaper than a half-bridge class D amplifier.....since with a full-bridge class D, your using the full rail voltage....not just half of it.?
Hi, my 2 cents....
Half bridge amp is easier, but you have to deal with supply pumping > bigger SMPS
Full bridge amp is more tricky but only a single rail is needed and no supply pumping > simpler SMPS
Neither are easy to do as DIY as both requires detailed knowlede regarding the custom designed magnetics required in both cases.
For most DIY projects I would recommend to only design the amp, and not worrie about the SMPS as this involves working with lethal!! voltages.
Stay on the secondary side of a standard SMPS module - they can be sourced from different companies, or simply use a standard 50/60Hz transformer and rectifier.... this works well for most DIY projects!
I wish you the best of luck with your projects.
\\\Jens
Full Bridge SMPS is cheaper than Half-Bridge? eem2am Power Supplies 18 28th April 2012 03:32 PM
Half bridge Vs full bridge smps supplies jaiaditya4u Power Supplies 5 27th July 2011 05:12 AM
half-bridge VS. full-bridge gearheadgene Class D 3 25th May 2007 08:49 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Copyright 1999-2017 diyAudio
