| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
#22 |
DPA-400 is looking really good.
#23 |
Thank RainTalk.
The "F2" version (for guitar bass,sub etc as i said before). as you see, AP declare the rms power output Vs the lowest load in accordance with good performances. This means that the amps are much more generous in power. "F2" is declared 600w (4R) at 0.04% of thd, right for example. F2 height=30mm (ref to pcb) well...need F3 a this point
#24 |
Hi Roberto.
Do you know when your DPA-400 F3 Will be on your webshop? |
#25 |
Hi AP2
greetings what core you use in output inductor looks like SENDUST material core two parallel cores in the picture above warm regards andrew lebon
[image] |
#26 |
#27 | |
first of all it is my duty to say that these results are the product of a collaboration with other engineers in MDI Team. For toroids output, after testing with 16Amp output, under many aspects of behavior (all toroids available in the market), including the wire to be used and the way of winding. I got what I needed, with original AMIDON, solid wire (2x), so I excluded FERRITES couple or as other multi wired. This product includes all of our experience, especially on the definition of high band already obtained perfectly with the SDA-400 as AB Class. but it would not be possible to get this incredible new performance in the dynamics without another long study called "DPS-500/600" ![]() Regards Last edited by AP2; 28th September 2012 at 10:42 AM. |
#28 |
#29 | |
however, I think that the shop has been updated with the new F3. ![]() Regards |
#30 |
Yes I see Thank you! I sent you a email because I want to order four module but The delivery system can't accept it.
| Anyone one tried AudioPower.it yet? | fb | Class D | 15 | 5th February 2012 04:14 PM |
| Which design to have in-a-car-like sound pressure? | Doug Kim | Multi-Way | 39 | 29th July 2008 11:49 AM |
| Sound pressure in time domain | jamikl | Full Range | 6 | 26th March 2006 02:11 AM |
| Sound pressure, is that the same? | destroyer X | Solid State | 17 | 9th May 2004 11:51 PM |
