| Class D Switching Power Amplifiers and Power D/A conversion |
Quick (possibly stupid) question regarding those cctv li-ions you can get on ebay.
Some have a 5v USB out as well as the 12v normal out. Can you charge via the 5v port? I know it's a long shot but I'm wondering if anyone knows. |
#2 |
No. It's an output.
#3 |
Dammit, that's what I thought. Im trying to rig up some way of charging my boombox without removing the battery or opening it up.
#4 |
Does anyone know how I could rig this up. 5v usb input that will charge a 12v battery, lead acid or li-ion.
#5 |
USB power is +5V and 900mA (for version 2 or newer, and 500mA for version 1.1 or older), that's 4.5W output max. Even if we assume 90% charger efficiency that's only 4W. With a 12V 7Ah battery, that means a full recharge would take over 60 hours.
In other words, it's possible but it's not realistically something you'd wanna do. |
#6 |
Ah, ok. Cheers saturnus.
#7 |
Ok, on a related note, if I
1) mount a 2.5 power jack on the outside of my boombox 2) link this to a lead acid 3) link the lead acid to the amp 4) plugged a 13.5v 1A power supply into the external power jack Then everything should work, shouldn't it? The battery will charge (although slowly towards the end of the cycle) and won't be damaged (13.5v is float voltage). Amp will draw power from the supply if present, battery if not (well, sort of). I'll be able to plug it in and unplug it at will. Or am I missing something here? I was thinking something like this: AC Power Adapter For Sony Camera EVI-D30 13.5V 1A New | eBay or this: http://www.cableuniverse.co.uk/switc...-3a-13.8v.html (cheers for your continued help btw) Last edited by fraction; 3rd October 2011 at 12:51 PM. |
| Modifying USB cable to supply 5v | hillbear | PC Based | 107 | 7th August 2010 07:36 PM |
| polymer li-ion battery charging and charge status estimation | zilog | Everything Else | 5 | 18th June 2010 12:23 PM |
| Help with charging Li-ion cell | EWorkshop1708 | Power Supplies | 14 | 29th May 2008 03:59 PM |
| Split Rails off 5V USB | gbyleveldt | Digital Source | 4 | 9th October 2007 02:06 AM |
| Page generated in 0.08434 seconds (76.47% PHP - 23.53% MySQL) with 10 queries |
