Go Back   Home > Forums > Amplifiers > Class D
Old 14th September 2011, 03:06 AM   #1
Default Memphis 16-MCD1000 burnt gate resistors
A friend of mine has this amp which would power on and go into protect. I opened it up and found the gate resistors to be severely burnt. I tested them with an ohm meter and got 31 ohms on both. The Board had burnt so bad that the traces are completely gone on the one side of the resistors. I removed them and cleaned up the board but I can't find what trace they went to. The other side of the resistors go to a set of 4 diodes.
I don't understand how the board could have melted but yet the resistors are still good. Does the other side of the resistors go to a 12 volt pad on the board? I'm not having any luck finding a schematic for the amp. Here's a pic I took that didn't turn out the best but shows the burnt board.
Old 14th September 2011, 08:11 PM   #2
nigelwright7557's Avatar
I would guess the output mosfets have gone drawing a lot of current through the gate resistors.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 16th September 2011, 08:10 AM   #3
I know the fets would be easily replaced, but how would I go about replacing the traces to the gate resistors?
Old 17th September 2011, 03:45 PM   #4
The guy I got the amp from has another one of these and let me open it up. I took a pic and verified that the gate resistors each go to a diode on one side but the other side I couldn't see what trace they ran to because it was on the bottom of the board.
The amp I have still has the diode traces intact that lead to the resistors. Where do the gate resistors go to before they go to the diodes? I see the trace under C50 and C51 says LED GND. If I remember right, I tested voltage on that trace and it read 12 volts. Anyone know? I appreciate the help.
Old 17th September 2011, 10:20 PM   #5
The easiest way to fix fried traces is with wire links.
Scrape off the solder resist, tin the track and solder your wires to that.
Old 18th September 2011, 02:04 AM   #6
Yea I know how to repair a trace. I was just wondering if someone knew how I can find out what trace the resistors go to. What component goes to the resistors and then to the diodes? The board is literally melted on the amp right where it says C51.
It has no trace, just the inside of the board showing through and the 2 holes for the resistors. Does someone else have this amp or resources to a schematic? Maybe someone has come across pics of the board? Appreciate the help
Old 26th September 2011, 02:13 PM   #7
i have the same problem with my amp but my board is not melted and my amp will turn on and some what play but you can tell it has fried resisters and diodes. i have called memphis and they wont release the schematic because they still repair these amps
MTX JH600 w/burnt gate resistors Ronode Car Audio 2 2nd August 2011 06:38 PM
Memphis 16-mcd1000 bdgf2004 Car Audio 17 9th May 2011 05:47 AM
Memphis 16-MCD1000 output filter capacitors Ronode Car Audio 1 23rd March 2011 04:54 PM
Memphis 16-mc1000d mike49504 Car Audio 46 9th July 2010 09:06 PM
memphis 16-ST500D frt96 Car Audio 2 9th May 2008 07:16 AM
Page generated in 0.09099 seconds (74.24% PHP - 25.76% MySQL) with 10 queries
