2-ohm stable, but low power, amp?
Hi all, I'm trying to find an amplifier for a 2-ohm speaker load, but it only needs to be about 10-15W. I'm not sure if I should be posting here, or in the solid-state and/or chip amp forum, so please point me in the right direction :)
The speaker in question is a pair of HK Soundsticks that I got for free, ATPM 10.04 - Review: Harman Kardon Soundsticks II
They are 4-speaker mini line arrays, with a nominal 2-ohm impedance.
If anyone knows of one of the inexpensive commercially-available digital amps could handle a 2-ohm load, that would be ideal :) It wouldn't need to put out a lot of power...
Thanks for your help,
Eric
Class D amplifiers just have a current and a voltage output limit. Keeping the same peak output current level, output device dissipation does not increase for lower load impedances.
If you take a 100W 4 ohm class D module and use it at 50% to 70% of rated supply voltage (or just at 50% to 70% the rated signal level for full power), it will become a 25W to 50W 2 ohm amplifier (depending on design margins). The reduction in supply voltage is optional, just to avoid current limiting in modules that would shut down otherwise, and it only makes sense with modules that are still capable to work with the lower voltage.
So in other words, any class D amplifier can drive 2 ohms properly if either supply voltage or input signal are kept under control.
Ex-Moderator R.I.P.
Joined 2005
it just so happened that I actually heard those speakers the other day
I was shocked by the power
and it actually sounded quite nice too
even an old hifi geek like me was impressed
'ordinary' people probably just think... nice
but knowing just a bit about speaker design, you also know that this shouldn't be possible at all
those are just tweeter cones, with low Fs
looks like the small 1" Tangband
I doubt you can do this without the sub woofer module
all the electronics is in there
I reckon its 'stuffed' with EQ
funny thing is, even if the sub is made of clear plastic, there's not much to see in there either
its close to a mystery
