Go Back   Home > Forums > Amplifiers > Class D
Old 21st October 2011, 05:58 PM   #61
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
soldering should be easy if you do it dead bug style
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 24th October 2011, 03:24 PM   #62
Send a message via MSN to egberttheone
I have read the thread but it is no clear to me what you want to achieve.
Do you want more efficiency?
Smaller dead time ?
Less jitter ?
I'm interested in a low jitter mosfet bridge, the best driver i could find has 1ns of jitter which is pretty much.
Nice work BTW!
Old 25th October 2011, 05:22 PM   #63
elevator's Avatar
Smaller dead time ?
Less jitter ?
All of these, basically.
In a nutshell, eGaNs promise to deliver music cleaner, faster and more efficiently.
But to achieve these goals, electrical control must be tight, and mechanics also. The module embeds some (not all!) critical pieces while minimizing EMC etc. issues.
It should also make it somewhat easier to design a high-quality amp, so that eGaNs become accessible even to DIYers: most of them have trouble with SMD let alone bare dies...
Nice work BTW!
Thanks, work in progress!
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 27th October 2011, 08:21 PM   #64
elevator's Avatar
Originally Posted by Baldin View Post
How about the topside of the mos is it isolated, so that you can just press it towards a heatsink, to get proper cooling?
Kind regards Baldin
Hi Baldin,
sorry if this is late. Yes, the substrate (topside) is isolated. EPC has an appnote on assembling and soldering etc., pretty interesting and IMO a must read before kidding around with these critters.
It's here: http://epc-co.com/epc/documents/prod...aNassembly.pdf
Old 30th October 2011, 09:24 PM   #65
smms73 is offline smms73  Portugal
smms73's Avatar
Hello egberttheone.
I think the only drivers that have that much jitter are those that are based in optocouplers or digital isolators, normal drivers like irs2011 for example, don't specify jitter in data-sheet , how do you get that numbers for jitter, have you measure?
Old 31st October 2011, 11:55 AM   #66
I wish i had the ability to measure jitter. I found some jitter analyzer equipment but most of these can only measure as low as 1ns.
I would need one that can measure in pico seconds.
These are VERY expensive.
I found these jitter numbers in the datasheet, the driver did make use of opto isolators.
If there are no opto isolators involved what can i aspect in terms of jitter?
Most datasheets dont specify jitter.
Old 4th December 2011, 03:13 PM   #67
Originally Posted by EPCguy View Post
Thx for the warm welcome. I'll try to answer as much as I can.
There are many options for improving the 'usability' of our devices.
Wider pitch, better miller ratio, higher VTH and VGSmax, larger / better thermal package etc. Some are easier to do than others and are being looked into...
Pretty glad to hear this, because when your devices became available through digi key - I had a look to them and decide not to use them.
Mostly because of low Vth and insufficient capability to handle losses.
Of course we do not want to have losses, but my assumptions were as follows:
+/- 75V rails, half bridge 8 Ohms load.
I trust that I can design a PCB that allows power stage designs with di/dt around 1000A/us.
Consequently my designs would need approx 10ns for commutation at a 10A load. At a 1MHz switching frequency this would result in 7.5W losses in the device. My personal guess was that I would not be able to transfer this heat from the die to the heat sink.
Finally I decided, to go for MosFets in my current design and stay with 400kHz. In a few years GaN is likely to become mature enough for my purpose - I will wait for this.
Nevertheless, I am loving this thread. It is pioneering the application of future power switches. Absolutely great!!!
Old 5th December 2011, 10:59 PM   #68
elevator's Avatar
Originally Posted by ChocoHolic View Post
... Absolutely great!!!
Thanks Choco. As they say, road works ahead Will keep you posted
E
Old 18th April 2012, 03:12 PM   #69
bwaslo is offline bwaslo  United States
Has anyone gone further on using these eGan FETS as class-d amps? Wondering how it worked out...
Old 22nd April 2012, 11:06 PM   #70
elevator's Avatar
still sweating over it...
Half bridge Vs full bridge smps supplies jaiaditya4u Power Supplies 5 27th July 2011 05:12 AM
half-bridge to full-bridge nek antunes Power Supplies 3 27th May 2010 01:04 PM
half-bridge VS. full-bridge gearheadgene Class D 3 25th May 2007 08:49 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.11376 seconds (80.93% PHP - 19.07% MySQL) with 11 queries
