| Class D Switching Power Amplifiers and Power D/A conversion |
I have one interesting problem with all my prototypes of classD, they donot clip cleanely, like classAB, instead they clip like this (one photo finded on this forum).
I have tryied many feedback schematics, including self-osc or clocked designs, comparators LM311-LM319-AD8561, dead time with CD4070-74HC02-74HC14, drivers IR2110-6N137 and TC429, the same results. Even a Behringer PMH5000 distorts like this, unmoddified. I have developed one clipper schematic, sensing supply voltages and preventing this clipping, but i think this is a band aid. I want to know if this clipping is a normal thing in a full range classD, without any tricks (clipper, limiter). Even my sims (Philips Ucd, discrete design) indicates problems with recovery from clipping. Last edited by ionutgaga; 24th August 2011 at 11:47 AM. |
#2 |
Is your bootstrap cap running out of juice?
Warm regards Jens |
#3 |
They clip on both positive and negative, meaninig this is not a problem regarding bootstrap circuit. Offcourse, i have tryiet with floating small smps, the same result.
#4 |
Photos take it from Ucd based feedback, 370khz at idle, AD8561, 74HC02, IR2110, IRFB4332, +/-100v, T130-2, 40uH and 2uF.
#5 |
I'm not sure I understand the problem. Why do you want your amp to clip in the first place?
#6 |
This is normal
#7 |
A self-oscillating design will always stop oscillation when driven into clipping, and the reduction in switching frequency just before (and after) clipping is normal. The reasons for this are fairly well documented on the web. A well laid-out UCD design will exhibit a somewhat cleaner entry and exit of the clipping region than is shown in the photos, but what you show is fairly normal.
Don't forget that the bootstrap capacitor will be slowly discharging when the circuit is not switching, so make sure it has eenough capacitance. |
#8 |
I have had problems with clipping on the IRS2092.
Driving it hard is fine but if I hard clip it then the chip will sometimes gets upset and resets. IR just said dont overdrive it into hard clipping, useful reply lol They said if I apply more than 10 v pk to pk then it will upset the input and cause the chip to reset.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#9 |
In this topic ucd 25 watts to 1200 watts using 2 mosfets Eva says:
It is applicable with self-osc schematics? |
| Recovery from clipping, soft clipping | hahfran | Solid State | 49 | 23rd February 2010 01:03 AM |
| Am interested in ClassD | LEIQINGU | Introductions | 2 | 9th November 2007 09:02 PM |
| ClassD using LM311 | lumanauw | Class D | 2 | 27th August 2007 08:33 PM |
| New to ClassD | DarkOne | Class D | 2 | 24th September 2006 04:11 PM |
| Hard clipping a guitar signal | Skankadellic | Instruments and Amps | 4 | 22nd January 2004 02:29 AM |
| Page generated in 0.09474 seconds (80.08% PHP - 19.92% MySQL) with 11 queries |
