diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   DC input jack has 3 terminals ? (http://www.diyaudio.com/forums/class-d/194837-dc-input-jack-has-3-terminals.html)
johnviera 18th August 2011 01:49 AM
Why do DC input jacks have 3 terminals? Positive (+) Negative (-) and (?)?
Ground ??? Isn't Ground the same as negative ?
Like these: http://img.alibaba.com/wsphoto/v0/48...pg_200x200.jpg
JV
Jim McPherson 18th August 2011 02:35 AM
Ground != negative on many amplifiers. For instance: Many Tripath amps require -45v, +45v and "ground".
-Jim
theAnonymous1 18th August 2011 02:44 AM
Two of the terminals are touching when there isn't a plug inserted. When you insert a plug they disconnect, leaving only one in contact with the plug.
You could use this to charge a battery powered device. Inserting a plug would disconnect the load from the battery so only the battery is connnected to the charger.
I'm sure there are other uses as well.
CONN 2.1MM JACK W/HARD PNL MNT - PJ-005A
johnviera 18th August 2011 03:35 AM
Thanks. I see the short when disconnected and no short when plug is inserted. Thanks.
zerokelvin99 18th August 2011 10:24 PM
little voltage, big voltage and HUGEEEE VOLTAGE
sorry
Copyright 1999-2017 diyAudio
