Distortion Tests - HifimeDIY T2 / LJM L20D / SURE TDA7498
Old 30th September 2011, 06:08 AM   #41
ljm_ljm is offline ljm_ljm  China
Originally Posted by desibros View Post
Hello!, I'm sorry to use this tread but I don't know how to connect my new L20D ... The pinout on ebay page was not very clear... +70V to VCC+; -70V to VEE- and ground to PGND? The speaker + to OUT+ and speaker - to PGND?
Thank you a lot
max
In free time I draw a picture, may help.
By the way, power and voltage is connected.
L15D work 40 to 60 V DC (+-)125-150 W8R
L20D work DC 60-80 V (+-)200-250 W8R
According to from already the need to choose the better.
Old 8th October 2011, 04:50 AM   #42
MrSlim is offline MrSlim  Canada
Originally Posted by 454Casull View Post
Anybody know what the PSRR of the L20D is?
Since the L20D is based on the IRAUDAMP7S reference design, it should have the same PSRR as it, which is stated as -65 db at 1Khz
Old 28th October 2011, 01:38 AM   #43
noah katz is offline noah katz  United States
So with +/-60V the L15D gives 150w/8R and the L20D gives 200W?
At the same +/-60V, what are their idle power dissipations?
Also another question, if I may - what is the connection between ljm_ljm and zoe_tsang?
I've looked through the latter's ebay listings, including the ones being discusses here, and can't help but wonder kind of quality/reliability can be expected for such low prices.
Assuming there's a reassuring answer, what are the pros/cons of the single-channel boards vs. the stereo ones?
Noah
Old 28th October 2011, 02:48 AM   #44
Perhaps I should mention, application is 8 ohm speakers, with a dip in the midrange to 6 ohms.
Noah
Old 28th October 2011, 03:08 AM   #45
trevmar is offline trevmar  United States
The boards I got from zoe_tsang both worked properly, but I swapped out the main filter caps for 100V low ESR types. They were only 63V, and high-ish ESR. Best to consider Zoe's as "bargain basement" prototypes, and check them over carefully. I certainly didn't throw mine straight onto 65 Volts, although I could have done so... Both of my L20D drove 6 ohms without a hiccup and put more than 200W into my 4 ohm dummy load, which was almost glowing red with distress I didn't have a larger dummy load. No problems with dissipation, the L20D heatsink was always cool-ish, no matter what I threw at it. I was very happy with them. The output ran to within a few volts of the supply rails, almost regardless of 4-8 ohm loads.
Before buying the l25D I would want to see if the heavier capacitive load on the PWM driver chip might lead to a little higher distortion levels. The L20D distortion was so low it was difficult to measure...
Single channel boards give you control of the grounding. If that is important to you, I count it as the single most important difference between them. My testing was with single boards, no trace of ground routing problems.
Old 28th October 2011, 03:14 AM   #46
454Casull is offline 454Casull  Canada
There are so many questions flying around, somebody should do up a FAQ.
Anyway, one more into the fray: what's the maximum output current, and is there overload protection?
Old 28th October 2011, 03:21 AM   #47
Is zoe_tsang the only source for ljm's design?
Or does replacing the filter and input caps pretty much take care of it.
Though I'd much prefer something ready to go, and with speaker protection.
Something else I'm curious about: How long did it take other people to figure out that "European" means ohms/resistenace?
Noah
Old 28th October 2011, 04:39 AM   #48
The IRFI4020 data sheet and application note (iraudamp7s.pdf) has all this information. There are both peak and average current rating for the MOSFETs there.
Be warned that the overload protection with the additional transistors in the app note is not implemented in the L20D, but the IRS2092 internal overcurrent protection mechanisms are still active.
Old 28th October 2011, 05:45 PM   #49
L20D near power position has two 80 V150UF capacitor, they need more than compression VCC +
The voltage between GND.
Some 63 V22UF capacitance they work voltage is low, only need to more than 25 V is enough.
22 UF capacitance need high frequency, LOW ESR.
In addition L20D has a resistance, the default is 470 OHM. Can set PWM frequency
About 470 R = 550 K, 330 R = 440 K, 300 R = 400 K HZ.
Old 28th October 2011, 05:59 PM   #50
zoe_tsang was a good transportation network of dealers.
I know there are many inferior in China really fake parts and materials.
But I won't use these, I to the requirements of the quality of the very strict.
I'll in my products indicate the LJM letters.
Distortion Tests - HifimeDIY T2 / LJM L20D / SURE TDA7498Hide this!Advertise here!
hifimediy T2 mods? bdbender Class D 21 11th March 2016 01:14 PM
WTB: Hifimediy T2 Frosteh Swap Meet 1 7th August 2011 09:03 PM
Improving Hifimediy t2 jtjy Class D 3 20th July 2011 06:02 PM
Power supply for Hifimediy T2 eladmi Power Supplies 0 10th March 2011 08:14 PM
Hifimediy T3 and T2 amps... oppinions? jaistanley Class D 6 30th November 2010 11:36 PM
Copyright ©1999-2017 diyAudio
