Distortion Tests - HifimeDIY T2 / LJM L20D / SURE TDA7498 - Page 8 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th August 2013, 08:22 AM   #71
First and foremost, thanks for such a meticulous analysis of the sure TDA7498 board. I got myself one and modified it according to your recommendations.
Now, my question is: I intend to design a custom board based on the TDA7498, and the load to drive is 4 ohm. I see you've tested 4 ohm with good results, but the datasheet only mentions 6 and 8 ohm loads. Is it safe to use 4 ohm long term or is there any associated quirk? (I'm thinking of, for example, short circuit protection).
Thanks.
Old 7th August 2013, 05:38 PM   #72
Saturnus's Avatar
Originally Posted by iggarpe View Post
Is it safe to use 4 ohm long term.
No. Hence the datasheet specifically only shows 6 and 8 ohms performance.
You can parallel the inputs and outputs however, and then it'll run 4 ohms. It'll be only 1 channel naturally though.
Old 7th August 2013, 08:02 PM   #73
Oops. The TDA7498E version is specified for 4 ohm, but it costs almost twice as much (no big deal for my app) and is much more diffcult to supply (big deal for my app).
Care to suggest a similar simple class D IC amp that can output 60+60W on 4 ohm loads?. (single positive supply rail)
And how would you parallel the outputs?. I mean before or after the LC filter?.
Old 8th August 2013, 11:13 AM   #74
SNY is offline SNY  Hungary
Default IRS2092
IRS2092 + IRFB4019 + T130-2 distortion tests without AES filter. (ESI Juli@)
Rail: +/- 50V DC
Load: 8 Ohm resistive
http://audiodiyers.hu
Old 21st January 2014, 10:00 PM   #75
Well, STA505 has the worse THD but it has the better sound for me, much better than STA510A / STA517 and TDA7498.
Xonar DX has lower distortion and higher SNR but I prefer a thousand a times more the Auzentech Forte sound....
Old 28th June 2014, 10:19 PM   #76
I'm searching for this, too.
Maybe someone achieved that in the meantime?
I would like to use this board from ebay (16 incl shipping) for a budget subwoofer project with an 4 ohmer.
edit:
TDA7498 (forgot to mention)
Old 29th July 2016, 09:23 AM   #77
Hi
one question
what is the Difference between L20D and IRAUDAMP7 schematic and output quality ?
which one is better ?
if you have L20D schematic please share it here for check it in difference
thank you
hifimediy T2 mods? bdbender Class D 21 11th March 2016 12:14 PM
WTB: Hifimediy T2 Frosteh Swap Meet 1 7th August 2011 08:03 PM
Improving Hifimediy t2 jtjy Class D 3 20th July 2011 05:02 PM
Power supply for Hifimediy T2 eladmi Power Supplies 0 10th March 2011 07:14 PM
Hifimediy T3 and T2 amps... oppinions? jaistanley Class D 6 30th November 2010 10:36 PM
Copyright 1999-2017 diyAudio
