| Class D Switching Power Amplifiers and Power D/A conversion |
I have a class d amplfier where the three outputs are used ie two normal stereo chnls out & third chnl to small subwoofer. Can i connect a line output from the the two stereo chnl ouput crossover boards safely or is there a better option, i want to use this to drive my external active bookshelf speakers which are not very sensitive but have their own tone controls. Any advice or suggestions would be "very much appreciated".
From. Radams23j6. |
#2 |
This is the area for forum problems, not audio problems. I'm sure one of the mods will move it to the right place.
#3 |
Hi! df96 i have not been on this site for a long while, so as a consequece of this fact i am stumbling around to reaquaint myself with the workings of this site, and will get it correct eventually with a little tolerance of this fact from the more adept & informed members on this site.
Many! Thanks. From. Member. Radams23j6. |
#5 |
If I understand you correctly, then no, you unfortunately cannot connect any line-level gear to the outputs of Class-D amps. (I'm sure it's technically possible - somehow! - in theory, but in practice it isn't done.)
And the power of the bookshelves cannot be boosted this way either. These simple things are surprisingly complicated ![]() But I'm not 100% sure we're on the same page. I hope my answers make sense and are appropriate for the question
| Looking for advice with D class amplifier choice | Adam Bernau | Class D | 10 | 5th November 2010 05:15 PM |
| Class D amplifier Power Output | ndsonu | Class D | 6 | 28th October 2009 04:08 PM |
| Recommended output transistor for Class A amplifier | aldovan | Solid State | 5 | 15th February 2008 02:42 AM |
| Page generated in 0.07931 seconds (73.15% PHP - 26.85% MySQL) with 10 queries |
