Output transistor temperature changes with load characteristics.. - Page 9 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 19th August 2011, 08:02 PM   #81
darkfenriz's Avatar
Ripple current is the current that flows through output inductor at switching frequency. It causes losses in inductor's wires, mosfets' Rdson and capacitors' ESR.
Old 22nd August 2011, 07:28 AM   #82
Originally Posted by darkfenriz View Post
For below 60V IRFB3806 are the best.
For 60 to 75V you can try more powerful IRFB3607.
My battery voltage will be near 60V and if the load is assumed inductive so I preferred Vds>=100V mosfets. I found IRF6645 is the best among VDS>=100V FETs. Am I wrong?
Old 22nd August 2011, 07:57 AM   #83
Originally Posted by Pafi View Post
Anyway: changing the whole circuit before knowing what is the real problem, doesn't seem to be wise.
I suspected the small sign of turning on again at the lower gates. I'm trying to lower it.
I don't really understand why to measure (only) without load. Loss components are different without load. And you won't use it this way.
The previous waveforms were perfectly normal (except for the current, which is unexplainable). There is a small sign of turning on again at switched off gates. This is usual, but can cause cross conduction! Harder gate pull down, or increased Cgs may help!
I got the lower gate voltages when the load is resistive or inductive.
when it is loaded resistively small voltage spikes seen on both gate voltage.
but when it is loaded inductively the spikes too high!
Is that normal the gate voltage having high spikes with inductive load?
A little spike is expected but this much more than expected. Also as you can see the behavior is not the same although at the same edges of the signals!?
Old 22nd August 2011, 10:07 AM   #84
Denniz is offline Denniz  Russian Federation
Thank You.
Old 22nd August 2011, 10:14 AM   #85
There is a small sign of turning on again at switched off gates. This is usual...
Hmmm... Why is it usual? What is the reason for that turning on again?
Thank You in advance.
Old 22nd August 2011, 10:33 AM   #86
Pafi is offline Pafi  Hungary
What is the reason of that turning on again?
Cgd injects charge to gate while Vds is increasing. The opposite impulse also can be seen at negative Vds edge, when it is not caused by the FET itself.
Old 22nd August 2011, 10:57 AM   #87
Thank You.
Looks like it is an "unavoidable" effect?
And what is the reason this time?
Thanks.
Old 22nd August 2011, 08:01 PM   #88
darkfenriz's Avatar
A small capacitor (~330pF) directly at gate to source terminals can tell if that's really miller Cgd problem.
This capacitor slows down di/dt phase but leaves dv/dt basically same fast, and paracitic capacitance divider Cgd/Cgs will hopefully divide enough now to stay below Vgs threshold.
Try it now just for fault tracing
Old 24th August 2011, 06:40 PM   #89
The same.
NFB and load characteristics niko084 Solid State 51 8th March 2011 05:51 AM
Transistor and Temperature lumanauw Solid State 10 12th September 2004 09:44 PM
MC load, normal input characteristics peranders Analogue Source 34 1st October 2002 10:50 PM
Copyright 1999-2017 diyAudio
