Good fanless Mean-Well supplies, 24V+, 150-220W
Old 8th August 2011, 12:26 PM   #1
kristleifur is offline kristleifur  Iceland
Default Good fanless Mean-Well supplies, 24V+, 150-220W
Hi all,
I was looking through MeanWell's catalog of supplies and made a shortlist of supplies that should work well with TK2050 Tripath amps and other single-rail Class D amps. I hope this info is useful for someone.
I just ordered the fanless HRPG-200 from Mouser in 24V.
Details at Mouser. Datasheet.
I found these other fanless 24V supplies between 150W and 200W; Noise is around 150mV P-P for 24V, switching frequency is outside the audio band (60KHz and higher), and they work on universal voltage:
Plastic, fully enclosed:
  • GS220 - external enclosed brick type supply; 220W and fanless; High efficiency (over 90%). I didn't pick it 'cause it was €20 more than the HRPG-200, and a tiny little bit noisier (180mV), and most of all, it would probably run hotter in the enclosed case I'm putting my amp in.
In-case supplies, enclosed in aluminium shield, with adjustable voltage by about 10%:
  • HRP-150
  • HRP-200
  • HRPG-150
  • HRPG-200
  • SP-150
I took the HRPG-200 because of the 5-year warranty, good regulation (0.2% line and load), larger adjustment range of output voltage, highest power without a fan, and better cooling properties than the plastic GS series.
The SP has the lowest cost, and the GS-220 is interesting for its high efficiency, high power, and that it is fully enclosed and protected.
150W should be enough for two channels of 24V into 4 Ohms with the TK2050. If you take these supplies to their output maximum of about 28V, then 200W is what you want.
Please find further details in my post at the 41Hz forum.
Good fanless Mean-Well supplies, 24V+, 150-220WHide this!Advertise here!
2A 24V power supplies / 10qty. JHelms Swap Meet 2 7th June 2011 04:07 PM
cabiant for Xpload 220w Hosam Subwoofers 19 12th March 2011 05:37 AM
Meanwell 12V and 24V power supplies SMPS boywonder Swap Meet 2 21st September 2010 02:56 AM
So Sick of SEARCHING, help me find a good +/- 24v regulator PLEASE! Destroyer OS Solid State 28 12th October 2008 07:39 PM
Is it Good to regulate supplies? hacknet Tubes / Valves 21 6th May 2004 07:32 AM
Copyright ©1999-2017 diyAudio
