Go Back   Home > Forums > Amplifiers > Class D
Old 4th August 2011, 09:07 PM   #1
Default Which AMP Should I Use?
I am building a portable boombox running on a 12V 7Ah battery. I am powering two 5.25" Coaxial drivers. (93 db sensitivity).
Which amp should I use:
The Dayton DTA-2
The Lepai TA2020
or
The SURE TA2024
I am worried about the voltage requirements for the SURE TA2024. I heard it will perform better at 24V. I a using a 12V power source.
Thanks,
JV
Old 5th August 2011, 10:03 AM   #2
I'm pretty sure that that voltage spec is wrong for the Sure amp. That chipset only takes about and just over 12V max, like the others.
I would get the 41Hz Amp6-BASIC preassembled. It is recommended by Saturnus in his very well respected and established Boominator design. It is a solid design built with very good parts. Very reliable and you don't get much better sounding implementations of the Tripath chip than this. This is a no brainer.
Link: 41Hz Audio:AMP6-BASIC Assembled
Old 5th August 2011, 10:21 AM   #3
You prefer it to the mkII amp?
How much current does it draw? Is there a spec sheet?
I live in the USA. So the price and shipping is a bit high.
Maybe I can start a prototype with one of the aforementioned amps and then switch it to the amp6 in the future.
Thanks for your reply.
Old 5th August 2011, 11:31 AM   #4
It is generally regarded as the most solid implementation of the ~12V Tripath amps. However, I don't have personal experience with any of the other ones.
The current draw is much the same as the other amps you listed; There is probably some info on it in the Boominator thread: The Boominator - another stab at the ultimate party machine
At any rate, there is always the supreme rule: Build it wrong, but build it
Old 5th August 2011, 11:34 AM   #5
(P.s.: This one by HelderHifi looks better IMO than the Sure / Lepai / Dayton: TA2020 MKIII :: . ... the components look to be beefier. I don't see the price, but it's probably cheaper than the Amp6.)
Old 5th August 2011, 10:29 PM   #6
Yeas. I like the Helder HiFi amps. I sent him an email asking about the price and the current draw of the ta2020 vs the ta2024.
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Page generated in 0.09453 seconds (76.85% PHP - 23.15% MySQL) with 10 queries
