An amplifier without any heating
This is not (practically) possible. Per your example of 300W output, let's be generous and say that is across two channels instead of one, so 2 x 8 ohm (speakers) load = 16 ohm. That means 18.75V rail to rail output through a couple of mosfets each channel, 4 total so let's add 0.8V for those (an impossibly low 0.2V each just to show how impossible the whole idea is), . 300W / (18.75V + 0.8V) = 15A current, and this ignores all the losses in the amp anywhere else including the PSU.
15A * 0.8V = 12W loss (heat) in the last pairs of output transistors alone.
Sorry, I wrong dissipation. (not remember, but voltage loss is right)
Mosfet use in SDA-300 have 50mR static rdson.
power stage not use shunt.
@4R (300w) rail=50V; output clip @ 49,2vp
then dissipation is 9,2w.
for audio use, not require a heatSink. (only small profile in photo)
What?????
Where the hell did you get those numbers from?
And how could you ignore Ohm's law? (16ohm, 18.75V, 15A ???)
Theoretical maximum efficiency is 1-(Rdson/Rload). For example with FDP3652 (Rdson=16 mohm, Rload=4 ohm) 99.6 %. But in reality switching loss is dominant in most cases.
And as it's commonly known, nobody listen for sine wave, but music, which has a much lower average power than peak.
