Mmats class d
i was replacing the mosfets in the amp because i didnt visually see anything else wrong with the amp.. i ordered a bunch of irf3205 to replace them... the original on the power side were irf3710 and output was P80NE... the thing is.. i replace them all with irf3205 and when i tested it after i was done.. it was cool the protection light clicked on as it usually does at the beginning and then it went in to power mode... then i saw the power light start flickering and bam it pop a mosfet or two on the power side.. this all happened within like 5 seconds with no load on the amp... is this because i replace with irf3205 or for some other reason.. and if its another reason what am i looking for? im kinda new to this.. thanks
