| Class D Switching Power Amplifiers and Power D/A conversion |
Hello,
I can buy a second hand Audiolab 8000a for £125 or thereabouts from eBay, and I know that I like the sound they produce. My question is this: For the same money, can I build a Class D Amp that will outperform the Audiolab? If so, what parts would you recommend? Thanks |
#2 |
I assume you have no experience with class D, so I would say buy kit from 41Hz.com or already made product from hypex.nl
Or find different amp, 2nd hand is 2nd hand, far cheaper in most cases |
#3 | |
Remember, you need the board, a power supply, case, potentiometer, in- and outputs. From $80 up to €100 for a good power supply alone. And you might have 3 dealers and $30-$40 for shipping. Last edited by Ampit; 20th July 2011 at 08:24 AM. |
#4 |
Hifimediy T2 TK2050 2*100W@4ohm + Meanwell 27V 350W = £74 delivered.
I'm guessing I can get /make the other items for less than £50. |
#5 |
Not if it is truly to be an equivalent to the 8000a i.e. nice case, pre-amp and possibly phono functions as well. Just the power amp sections in a cheap box is as you say just about do-able.
#6 |
Sorry, I should have been clearer. I meant purely for sound quality, not looks and other functionality.
#7 |
I think you will find that DIY always ends up costing more then you'd expect. £125 for the Audiolab is very good value, especially as you know you like it. Personally I would grab the 8000A. This has the advantage of coming with a pair of preouts, should you wish to try class D in the future you'll have a good preamp for driving it with.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#8 |
Having owned an Audiolab 8000a for seeveral years, there are things it does that no T-amp can (or not very well).
The loudspeakers that you plan on using with the D-amp is paramount in my mind. If you have loudspeakers with 1 3rd order X-over or greater, and they are less than efficient, then I would recommend the Audiolab. The fact that an old Audiolab if in good repair has a lot of control and the ability to drive some fairly nasty impedaences is a bonus. So is the preamp section which includes a (quite) good phono stage (both MC and MM). If you have efficient loudspeakers with 90 dB+ sensitivity, and don't need a full featured pre-amp, then a Cllass D amp is a good choice. You will need something that has a volume control and the number of inputs that you require. The 41hz amps are veery good kits, as already stated. If you require a ready made solution, the Bantum amplifiers are nice. If you can stretch £'s. then perhaps a Virtue Audio One.2 .
stew ☮ -"A sane man in an insane world appears insane." |
| Audiolab 8000a | dantzig65 | Solid State | 9 | 6th June 2011 02:48 PM |
| Audiolab 8000A Fault | rjweatherill | Solid State | 26 | 24th March 2008 07:40 AM |
| Help! Audiolab 8000A | Matthewong | Solid State | 9 | 15th October 2007 06:09 PM |
| audiolab 8000a | davephot | Solid State | 35 | 26th November 2006 10:25 PM |
| Page generated in 0.09161 seconds (76.73% PHP - 23.27% MySQL) with 10 queries |
