Which Hifimediy Board for these speakers?
Old 18th July 2011, 12:06 PM   #1
TylerDurden is offline TylerDurden  United Kingdom
TylerDurden's Avatar
Default Which Hifimediy Board for these speakers?
As the title says really.
Here is the speakers spec-
Enclosure type: 2-way reflex
Bass Unit: 125mm
Treble Unit: 25mm
Frequency Response: 64Hz - 22kHz
Nominal Impedance: 6Ω
Minimum Impedance: 4Ω
Sensitivity: 88dB
Recommended Power: 25 - 75w
Crossover Frequency: 2.9kHz
Dimensions H/D/W mm: 264.5 x 278 x 170
Weight: 5.0kg
Old 18th July 2011, 03:01 PM   #2
goosewing is offline goosewing  United Kingdom
T2 or T3.
Old 18th July 2011, 03:04 PM   #3
Thank you.
And would the T2 be significantly better than an amp based on the TA2020 chip?
Old 18th July 2011, 09:02 PM   #4
If you are planning to keep your 88db speakers then yes I think the T2 will be significantly better as the TA2020 may struggle to provide sufficient output for typical listening levels. . If you plan on changing to considerably more sensitive speakers and/or listen mainly to non dynamic music at fairly quiet levels then it would just come down to personal preference on SQ.
Which Hifimediy Board for these speakers?Hide this!Advertise here!
hifimediy T2 mods? bdbender Class D 21 11th March 2016 12:14 PM
Hifimediy T4 board TheDealer Class D 313 19th May 2012 05:06 PM
Rega/classdaudio/hifimediy? Frankenrega Class D 5 9th June 2011 01:24 PM
FS: TK2050 Hifimediy AMP mravlca Swap Meet 6 28th April 2011 10:19 PM
Power supply for Hifimediy T2 eladmi Power Supplies 0 10th March 2011 07:14 PM
