| Class D Switching Power Amplifiers and Power D/A conversion |
Hello,
For the past months I've been designing a pcb for the tripath ta2020. I have read almost all information there is on this particular amp. One thing that however troubles my mind is the so called "pop noise" when turning on/off the amplifier. According to the datasheet the ta2020 has build in "turn-on & turn-off pop suppression". My question, is the build in pop suppression any good or should I invest in a solution involving a relay? |
#2 |
I cant speak for the 2020 but the irs2092 randomly pops on power off.
For some reason some chips do it and others dont. The reset circuit is only one capacitor so its hard to get wrong !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Don't forget that anything you connect to it's input might also cause pops, so it's a good idea to use anti-pop measures in any case.
Mike |
#4 | ||
#5 |
The IRS2092 has a capacitor on its reset input.
This sets the time constant for the reset cycle.
#6 |
I was talking about anything connected to an amplifier input will cause noise when it's turned on or off. A way of disconnecting and protecting speakers will prevent that. Take a look at this for ideas.
Loudspeaker Protection and Muting Mike |
| "Gold pin" Texas Instr. tripath TA2020 chips? | charliefreak100 | Class D | 0 | 7th June 2011 10:30 PM |
| CS4398 evaluation board schematic - Values for R and C's marked with "NO POP" | Groundloops | Digital Source | 4 | 5th April 2011 11:55 AM |
| Reduce "pop" noise when power on/off | veckans | Class D | 11 | 28th January 2009 09:53 AM |
| here "pop" there "pop" pls help! | tone | Digital Source | 7 | 30th May 2003 07:17 PM |
| Need help with IC Based Amplifier "pop" problem (Integrated Component) | Monolith | Solid State | 7 | 13th March 2003 03:01 PM |
| Page generated in 0.08623 seconds (70.74% PHP - 29.26% MySQL) with 10 queries |
