| Class D Switching Power Amplifiers and Power D/A conversion |
#101 |
no indeed! its just an alim thing that i didnt respect im sure, you make vss and vaa out of ±B ?
edit: just realise my CSL was at min, maybe just that also, gonn borrow that oscillo tonight and check it out again Last edited by philuknow; 10th August 2011 at 11:25 AM. |
#102 |
I used dropper resistors from b+ and b- for VAA and VSS.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#103 |
update:
realized that my amp op was dead too.. strange thing, ordered some.. didnt have spare i made ±5V with ±B and external diodes, work great for now w8ting for op amps.. |
#104 |
cool to hear that
#105 |
got my pwm working, everything in small signal is ok, tho i dont have amplified signal, looked up csh csl, was at max, csd is waving aroung 200mv referenced to gnd. got the same signal input as output 2Vp-p (by fb ?) nothing on HO LO, and Vb referenced to -B is 0V ???? tell me what you think.. not quiet sure bout the real source
edit: realised csd was waving in same time as pwm Last edited by philuknow; 16th August 2011 at 02:28 AM. |
#106 |
Vb can not be 0v compared to -B and for that you don't even need scope, are you sure you measure those two pins?
Where do you get this pwm? sounds like it wants to start, I think I had it like this, but I couldn't supply enough voltage for upper fet (since he wanted to oscillate at lower MHz range) I still think your voltages are off, can you check that again Also, you could be at the point I was, where I needed strong input signal, to make it operational, then it worked, untill switched off again BUT FIRST, how much is your Cfilter and remove it... I had it, and I had problems setting any higher freq, also amp started harder Last edited by luka; 16th August 2011 at 06:25 AM. |
#107 |
i didnt put Cfilter
pwm is from pin comp i'm sure about Vb, no doubt, dont have i didnt put R18 which charge cap on first oscillation tho my input signal is kinda strong 2Vp-p is CSD ok ? it is not supposed to be Vaa ? |
#108 |
just realised it... pwm freq is about 60Hz (which is my input signal)
i guess its not normal uh ? |
#109 |
My PWM frequccny is about 250KHz. I can see the residual PWM on the output signal just a few volts.
#110 |
and I have 480k, so no, anything below 100k is not good
| Order Confirmation | TjongKristian | Chipamp | 1 | 23rd November 2009 10:15 PM |
