| Class D Switching Power Amplifiers and Power D/A conversion |
Ok, so in my research to find what amp I might buy next, I discovered this site and the possibility of building one myself.
I have been lead to the TK2050, and more specifically to the Sure Electronics WebSite. There I have found these items available for about £80 ($130 inc delivery) 2*100W@4ohm TK2050 ClassD Audio Amplifier Upgraded 27VDC 13A 351W Power Supply (AA-AB32181 + PT-IP012) Aluminium Alloy Case for 2x100W Class-D Digital Audio Amplifier Other than the Amp, the PSU and the Case, what else am I going to need to complete the amp and get the "retail" look I'm after? Many Thanks for your help. |
#2 |
Any pots, switches, and knobs for front panel control.
input jacks for line level L-R signals output jacks for speakers Miscellaneous hardware such as an AC cord, PCB standoffs, wire, fasteners, etc.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
Thanks for the input. You have highlighted how little I know about this subject, and got me thinking I perhaps should just buy a Dayton Audio DTA-100a and be done with it!
If I do still build, doesn't the amp I linked to already have input jacks? and appears to come with output jacks, ![]() wire and fasteners too. ![]() The case has some slots, that I thought would hold the amp board in place, will this mean I don't need PCB Standoffs either? ![]() Not sure what a Pot is, is that the volume control? The only switch is for power, so do you have any recommendations for either or both of these? Again, thanks in advance for any help. If all goes well, I plan on making a "How To" guide that could help avoid these type of questions in the future. |
#4 |
#5 |
That "Rotary Encoder and Volume controll" board would just make things more complicated because you would need another power supply (5V) .....
Just get a 10K Dual Potentiometer (cost you maybe $2.50) and use that for Volume controll , or if your preamp allready has a Volume controll then you don"t really need one on the amp ..... Cheers |
#6 | |
#7 | |
49 - for the 16th time
Do you have a soldering iron or solder station? Some of those wires look as if they will need to be soldered to the circuit board.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod |
#8 |
| diyparadise amp module with Smps Psu and 19" rack case | Code | Swap Meet | 10 | 5th November 2010 09:51 AM |
| how to build a regulated psu to drive an op-amp? | figge77 | Power Supplies | 7 | 19th May 2009 10:47 PM |
| How to get inexpensive case/psu for Charlize & ilk | KeithC | Class D | 6 | 2nd August 2006 12:53 PM |
| Newbie want to build simple tube preamp&psu!need help! | thomgun_lc | Tubes / Valves | 55 | 29th November 2005 02:08 PM |
| Found this amp case in Oz | rabbitz | Parts | 3 | 10th December 2004 01:22 PM |
| Page generated in 0.10294 seconds (78.49% PHP - 21.51% MySQL) with 10 queries |
