Go Back   Home > Forums > Amplifiers > Class D
Old 11th July 2011, 06:10 PM   #1
BlaSe is offline BlaSe  Austria
Default 8 Channel Class D Project TPA3122
I'm working on a Board that should hold 4 of the TPA3122's in Stereo mode to power a speaker array. (multible boards are used to get a 4x4 or even bigger array)
I have finished the layout in eagle and I have some questions.
1. Is it allowed to sum the voltage stabilization caps to one or two bigger ones when having 4 of the amps on a small board?
2. Because of the limitations of the free Eagle version i am limited in space, so the GND that connects the components farthest from the supply have only a thin connection. Is that bad? ( I thouth about using a wire to strengthen the connection)
3. The board will actually be produced by a PCB manufacturer.
Can anybody see obvious errors on the board.
DRC only gives ma some stop mask errors.
Thanks for the help.
regards
Sebastian
Old 12th July 2011, 03:47 AM   #2
You're going to run into problems with heterodyning of the carrier frequencies through the rails with 4 chips. Even completely decoupling the power supply won't get you interference free output. You would need to have 4 separate power supplies and each amp isolated.
A better solution is to use 8x TPA3106D1 which can be used in a master/slave configuration for the oscillators. If you are limited in space, I'd go with one chip per board, jumpers for the master/slave oscillator links through twisted pair wires, use a single smaller local power supply cap, wide power traces, and a single PS board with big reservoir caps.
Old 12th July 2011, 04:47 AM   #3
theAnonymous1's Avatar
Two large supply caps is a bad idea IMO. You need two per IC as close to the supply pins as possible. 4x 3122 on the same board is probably a bad idea as well.
I recently finished making a layout for 4x TPA3106D1 (synced) for use in my car. Just need to find time to make the board.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 12th July 2011, 04:01 PM   #4
how strong would that interferences be?
i'm not planing on getting the maximum power/volume out of the amps and i'm using very small speakers.
Old 13th July 2011, 05:03 AM   #5
If the frequency was in the audible range, you would constantly hear a tone or tones that won't go away. Do a search in this forum. There was another member who ran into this problem with two TPA3xxx parts on a board where he describes what he encountered.
Old 17th September 2011, 11:33 AM   #6
Update:
Despite your warnings i built the thing....and see there. No Problems at all.
Works quite well with a simple switching power supply from a external harddrive.
So don't fear putting more than one Amp of this kind on one board.
S
TPA3122 doesn't work Joku Class D 35 19th November 2011 02:07 PM
TPA3122 - not working. Nothing aviatorbja Class D 17 26th July 2011 06:10 PM
TPA3122 aditya Class D 2 10th April 2011 10:23 PM
TPA3122 Groundings Cyberzim Class D 6 18th September 2009 11:28 PM
Class D TAS 5261/TPA3122 jash2008 Class D 13 3rd August 2009 05:35 PM
Page generated in 0.08511 seconds (75.88% PHP - 24.12% MySQL) with 11 queries
