Go Back   Home > Forums > Amplifiers > Class D
Old 10th July 2011, 07:53 PM   #1
Default Power Supply for Class D Amplifiers
Hi Guys,
Im building a class d amplifier (traditional,not ucd), Im using a signal generator for triangle reff signal and HIP4080 gate driver for mosfets. My amplifier will be BTL class and has max 30-50 W for 4 Ohm speaker. My question is about power supply.
I don't want to build a power supply, I wanna buy new one. For my amplifiers specs., what is power supply's spec. be? I think 20-25V 4A max current smps is enough for me. What do you think? And how am I calculate current and voltage requirements from supply?
And last silly question. My amplifiers power is (RMS current on load(speaker))^2 * impedance of speaker ? is it so easy?
Thanks..
Old 10th July 2011, 08:33 PM   #2
nigelwright7557's Avatar
Yes power is I squared R.
You can use a SMPS or a normal power supply.
Have a look on ebay.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th July 2011, 09:11 PM   #3
Thank you. But i want to learn which spec. is supply has?(for in spacing that i said)
For ex, how much current is my circuit take(max current)?
Old 10th July 2011, 10:54 PM   #4
It takes about 100VA.
I would go for 150VA supply.
Old 13th July 2011, 08:03 PM   #5
My notebook's power supply(smps) is 20Vdc and 3,25 A. Is it enough for experiment? I don't need high power, because of BTL structure. Can I use? Is max current of supply inhibitory?
Old 11th August 2011, 06:19 PM   #6
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Default POWER SUPPLY FOR CLASS D AMPS
Can you use a transformer that unregulated output?
Old 12th August 2011, 12:04 AM   #7
trevmar is offline trevmar  United States
No, usually the transformer-based unregulated power 'bricks' have a much higher no-load voltage than the rated value.
Any laptop power-supply 'brick' is usually OK, however. You can usually tell by the shape and weight whether they are transformer based (bad) or switching-supplies (good).
Power Transformer for Class A Amplifiers -- What are your experiences ? EUVL Pass Labs 20 3rd March 2011 08:06 PM
For sale, 2 x Hypex Ucd180HG class-d amplifiers 1x SMPS180 Power Supply. cirrus18 Swap Meet 0 16th May 2009 08:24 AM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
non surface mount class D mono audio power amplifiers Conor Digital Source 9 4th February 2002 08:14 PM
Page generated in 0.09226 seconds (75.08% PHP - 24.92% MySQL) with 10 queries
