| Class D Switching Power Amplifiers and Power D/A conversion |
Hello folks,
Sorry but I have a question. I just have several load's all in Parallel with the net load happens to be just 1 ohm. I am actually a Newbie in the class D filed, so my question is if class D amplifiers are good enough to drive a such low load? Or there is a problem while doing a such job? I know that for common class AB chips like LM3886T I can not drive the sad load other than adding several other chips all in Parallel. But please enlighten me about Class D amplifiers? Thanks a bunch
#2 |
I don't think it matters what class the amplifier is, a particular amp of any class will be optimised for a particular load and (usually) also able to drive lower impedances to some degree. And one ohm is not the load that amplifiers are generally optimised for.
Are you able to connect your loads in series/parallel and hence return to more standard impedances? That would ease the problems of finding a suitable amplifier greatly. |
#3 |
No problem with our amplifiers, for example (www.coldamp.com). In general, as long as you don't exceed the overcurrent limit, it is fine (this means that you will have max voltage excursion limited: for example, if the current limit is 20A (approx that in our S450 amplifiers), you will go to 20Vpeak (or 200Wrms) and then it will protect itself. Some other amplifiers are not designed to handle large currents, then you will run into problems. If you need more current, you will need a more powerful amplifier with higher current limit (as our S750), and limit the supply voltage.
#4 | |
#5 | |
In general it makes little sense to use such low impedance loads unless you are forced to run on low rails, such as in car audio applications (where for some costs or size reasons you don't want to use a DC/DC converter to raise the voltage). We are working on a very special (but audio) application for one customer that needs to drive 50 milliohm loads at 100-200W levels. |
#6 |
Thanks guys,
Before respond to your statements, I would like to know if I am able to use a transformer (something like a impedance matching transformer so that I drive my 1 ohm load by an amplifier essentially designed to work in 4 ohms?) P.s for ssanmor, Do you produce amplifiers? if so just what classes do you produce? |
#7 |
I have heard of people using transformers for impedance matching (in fact the customer I have mentioned is currently using transformers to power his 50 mohm speakers with normal amplifiers). I don't know how that will affect sound quality, but it will for sure not help.
Yes, we produce Class-D amplifiers and switching PSUs: have a look at www.coldamp.com |
#8 |
ssanmor, may as well short circuit your amps with that load!
i take it is some kind of VLF application, shaker motors perhaps? |
#9 |
No, it is for a new speaker development, ribbon based, full audio bandwidth. First tests are very revealing.
| LF55 & NAKSA70 and low impedance speaker load | supernet | AKSA | 4 | 17th January 2012 03:21 AM |
| Possible to design a high-power class D amp with a low output impedance? | 454Casull | Class D | 2 | 23rd February 2009 07:33 PM |
| Class-T amp driving low impedance? | Nuuk | Class D | 9 | 19th September 2008 03:22 AM |
| Class D and Very Low Impedance loads | Bruno Putzeys | Class D | 30 | 3rd August 2005 08:38 AM |
| Page generated in 0.10598 seconds (77.50% PHP - 22.50% MySQL) with 10 queries |
