Go Back   Home > Forums > Amplifiers > Class D
Old 7th July 2011, 01:07 AM   #1
Default 41HZ AMP 6B POWER SUPPLY
Hi all i have been useing a 41hz amp 6 for a while now but i have noticed the transformer in the 13.8 v power supply is geting noisy huming. Would this nois from the transformer impair the sound. I would allso like to know if droping the voltage from 13.8v to 12v would make the amp lose much power im useing tannoy dc 3000s which i built my self and are 91db so fairly sensative
Old 7th July 2011, 02:44 PM   #2
ANY HELP PLEASE
Old 11th July 2011, 01:53 PM   #3
Must be a very difficult question seen as no one can answer
Old 11th July 2011, 02:05 PM   #4
Pano is offline Pano  United States
Pano's Avatar
I don't think the transformer buzzing would get into the electrical signal, but I've never had this problem. You should still figure out why the buzz, it could indicate a problem.
You will lose a little headroom running at 12V, but it will run cooler. That said, I never had trouble running the AMP 6 at 13.5V if the amp case is used as a heat sink. I've built many of these.
Take the Speaker Voltage Test!
Old 11th July 2011, 02:40 PM   #5
Thanks very much for reply pano. Thay are fantastic little amps im useing a 13.5 bench supply and its the transformer that is buzzing it doesn.t seem to get hot i just wondered if there is a better power supply for the money. As i dont think im getting the best out of it i did use one of the brick type power supplys a while ago the ones thay use for lcd tv it did seem ok but like i said there only 12v
Old 11th July 2011, 02:55 PM   #6
Pano's Avatar
I was lucky in that I got to buy a lot of wall transformers at a good price. They were designed for a subwoofer but worked perfectly for the AMP 6.
Do you have the AMP6 with the power supply on board so that you need just ~12V AC?
Old 11th July 2011, 03:05 PM   #7
Hi pano no mine is one of those that needs a dc power supply its theamp 6 sneaky
Old 11th July 2011, 03:11 PM   #8
Pano's Avatar
OK, I see. In that case a good, solid SMPS at 12-13V or a linear supply will be fine. The linear can be regulated or not. I assume that's what you have with the buzzing transfo?
Old 11th July 2011, 03:28 PM   #9
Yes pano the one im useing now has 2 screw things in the front were you conect the amp to. If i wont loos too much power i might just get one of the smps power supplys that thay use for lcd tv. The problem with them is the voltage is 12v and then thay jump to 18v i cant find any at 13v or 14v so 12v will have to do
dual lm3886 41hz supply? nightanole Power Supplies 11 8th September 2010 08:48 PM
power supply for 41hz amp6 basic bull041161 Class D 3 27th April 2009 09:44 PM
Power transformer for 41hz amp6 ecl86 Class D 7 27th June 2007 10:06 PM
help powering 41hz amp3 and an active crossover on the same supply Nemophyle Class D 12 28th February 2007 08:59 PM
FS: Coral Flat 6B drivers harryz Swap Meet 0 2nd August 2006 08:16 AM
Page generated in 0.10977 seconds (73.72% PHP - 26.28% MySQL) with 10 queries
