Go Back   Home > Forums > Amplifiers > Class D
Old 30th June 2011, 11:25 AM   #1
Default Supply for Class D amplifier not split?
Hello
If there is a class D audio amplifier that runs off +24V, -24V
-Can i simply supply it with 48V instead?
Old 30th June 2011, 12:57 PM   #2
alexcp is offline alexcp  United States
alexcp's Avatar
No you cannot.
Old 30th June 2011, 01:23 PM   #3
Banned
How many threads are you going to start with the same question ????
That's three so far.
Old 30th June 2011, 01:28 PM   #4
ssanmor is offline ssanmor  Spain
No, you cannot, you need a ground reference.
If you need a +/-24V PSU just ask us (www.coldamp.com)
Old 1st July 2011, 12:38 PM   #5
Why not,
IRF shows in AN-1164 how it can be done.
Wants someone to try it?
Old 1st July 2011, 12:48 PM   #6
We have done many experiments about that, and the results were not good. Even when using an active bleeder the symmetry obtained is not suitable for mid to high power and low frequencies and can lead to many problems. Leaving apart that the transistors will dissipate quite a lot of power in these applications, ruining the efficiency of the switching power supply (if used) and Class-D amplifier.
Virtual grounds (even using opamps) are not a problem for small signals and are widely used, but for power stages they are not very recommendable.
Old 1st July 2011, 01:58 PM   #7
runebivrin's Avatar
Send a message via MSN to runebivrin
Or use two amps in bridge mode. That leaves the ground mostly signal level.
Do wizards use spell checkers?
Old 2nd July 2011, 10:12 AM   #8
Pafi is offline Pafi  Hungary
In my PC amplifier I also use single supply splitted by two capacitors. The DC voltage is set by the amplifier via sub speaker. No need for dedicated active bleeder, neither bridged amp. The only thing needed is properly controlled output voltage: it's reference potential is composed from (positive rail+negative rail)/2 at DC, and output GND at AC.
(This amp is Class AB, but it makes no difference.)
High Current Class A Amplifier Supply Andy5112405 Power Supplies 3 10th June 2011 07:49 PM
A good 12v power supply to run small class D amplifier indoors? chipper Power Supplies 0 12th February 2010 02:28 AM
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
Class D Amplifier Power Supply Design -> 12,5 A @ +/-80V = 1000W selfservice Class D 22 1st September 2006 01:20 PM
Class-G amplifier with PWM supply ! B.I.G Chip Amps 2 19th March 2005 07:32 AM
Page generated in 0.07802 seconds (78.86% PHP - 21.14% MySQL) with 11 queries
