About TA2022 design designers LJM
Old 29th June 2011, 04:18 PM   #1
ljm_ljm is offline ljm_ljm  China
Default About TA2022 design designers LJM
I think a lot of people in this section have been in touch to TA2022 the IC.
It has real power and the family to use appropriate distortion. And it's very cheap.
But the chip is not easy to design. The group of linear regulator is excellent design scheme of the necessary.
Because of its impedance is not high, about 20 K ohms, so large input capacitance is also useful
I used the 3.3 UF MKP.
The necessary dc protection circuit and cut off the flow of TA2022 itself with protection. Can be a very good protection dc and short circuit.
Old 29th June 2011, 04:19 PM   #2
It can work in very good +-within 35 V. Far more than similar IC inter-class D.
And can be very good drive 4's speakers. At this time of power will reach 120 watts.
It is less than the distortion of the TDA8920, TA2020 TA2024
Old 3rd July 2011, 07:33 AM   #3
cityfeng is offline cityfeng
Do You have schematic, can you send to me please! cityfeng29@sina.com, thanks!
Old 7th July 2011, 03:03 PM   #4
WHERE FROM YOU
Old 26th October 2011, 01:32 PM   #5
Brusque is offline Brusque  Brazil
Brusque's Avatar
Hello LJM!
I made some tests using that board (that you've sent the picture).
I was very impressed. Testing it on the bench, without a heatsink, at about 40W@8R per channel, it started to lower it's gain after some time then it stabilized at about 10W per channel.
I also used it on a gig (I'm a guitar player) without heatsink, for about 4 hours without problem. My volume was fairly loud and I didn't noticed the output power reduction.
The protection schemes are great. The chip seens to be almost indestructible.
Regarding the audio quality, I've made no extensive tests but noticed nothing abnormal.
I'm an electronics R&D guy and would like to colaborate with you if you intend to work with this chip.
Best regards!
Brusque
Old 26th October 2011, 02:15 PM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Haha, untill it dies. The TA2022 is certainly not indestructable. I've had about three of them die on me in different situations over the last 6 years.
And why would you intentionally use it without some form of heatsink?
Old 26th October 2011, 02:45 PM   #7
Brusque's Avatar
Hello theAnonymous1;
Stress test.
Regards!
Old 31st October 2011, 02:01 AM   #8
Hello LJM!
Best regards!
Brusque
welcome to your opinion. Subsequent version I slightly revised the point.
This version is V1.3, it USES the LM7810 as IC power source,
And a resistor instead of 1 N4741 off. Its compatibility is better.
Is willing to provide all the necessary things. If you need anything.
Old 13th November 2011, 10:28 AM   #9
I suggest using the preamp collocation.
This can improve a lot of sound.
Old 22nd December 2011, 12:40 PM   #10
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Hi ljm_ljm,
I have recently received the TA2022 kit from Zoe_Tsang and the board is marked V1.1 with 2 resistors and 1 diode already soldered to the board.
One of the resistors replaces diode 12U but IC power source is LM7805, not LM7810.
Do I need LM7810 for the board to work correctly?
Steve
About TA2022 design designers LJMHide this!Advertise here!
Model designers dbaudio Swap Meet 0 15th October 2008 01:09 PM
Radiotron Designers Handbook Frazzled Tubes / Valves 15 26th March 2007 01:07 PM
Help with design/geometry for DIY table...designers wanted :) Glowbug Analogue Source 11 13th December 2006 09:58 AM
Any horn designers here jerluwoo Multi-Way 10 19th June 2006 06:58 AM
