My design L20D IRS2092+IRFI4020H 200W8R - Page 78 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 20th October 2013, 01:47 PM   #771
From redjr:
I certainly don't dislike the sound of the LJM ISR2092 based-amps. Goodness knows. I have 5 of his design so I'm happy. I'm sure the sound can be improved even more with better speakers and listening arrangement. None of which I have at the moment. Click the image to open in full size. I recently replaced a Sure module with one of Cristi's design and it does sound very, very good. Better than the LJM? I'm not so sure. That's a close call. Only because I've never done any real serious A/B listening/testing of the two.
I completly agree:
I am not an ingeener, but I think the most important is the result, so maybe we need some KPI or indicators to compare user satisfaction for class D chips and architectures.
Saying that, I don't really understand why there are so many discussions around post filters, etc... For me, this is just different architectures to compare, with a user approach.
For L15D, there are measurements done in another thread that prove the quality of the sound.
Maybe it is not as good as a $1000 amplifier, but the result is more than decent compare to some class B or other class D.
So, what else to discuss?
My system:
I have a LJM L15D with a Connexelectronic SMPS.
a chinese Matisse PREAMP,
a HIFIMEDIY SABRE DAC with a RASPBERRY as source.
I have to say it is not perfect with high frequencies (it is a little bit crispy), and low frequencies are a little bit flat, but the averall sound is really better than my expectations, and I have to say the sound quality is far better than my Denon Home cinema amplifier.
Old 20th October 2013, 07:35 PM   #772
wushuliu's Avatar
Originally Posted by camelator View Post
I completly agree:
My system:
The greater concern is whether the LJM boards on ebay now are performing to spec. From what I have read through this thread it sounds like initially they were fine but now at the very least some are not. When you buy these from ebay it's not like you are buying them from LJM, there is no seal of approval just because the board says 'LJM' so his measurements are irrelevant at this point. What you're hearing could be a poor implementation. If you like what you hear great, but I wouldn't judge the LJM IRS2092 vs other amps unless I knew for sure it was performing to spec.
Old 1st November 2013, 07:05 PM   #773
Hi, I'm projecting amplifier for home theater, I want to use irs2092s for all channels
there was a couple of questions, I will have 6 channels in a single package powered by sg3525
- Do I need to synchronize the 6 channels?
- Do 6 channels on a single board or different?
thank you
Old 14th November 2013, 03:45 PM   #774
Huey is offline Huey  United States
I'm planning on getting a couple of these modules to put togther an amplifier. I have a 300VA 115v to 38-0-38 toroid transformer to make a power supply with. This will give me an output voltage of around +/-55VDC. Which version is the proper one to go with this? The L15D or the L25D?
Also, this will be my first power supply. I see I need a bridge rectifier and output filter caps. Are any other components required or is it really that simple?
Old 16th November 2013, 12:48 AM   #775
After rereading some of this thread with my question in mind I see that the L15D can handle this voltage (a few posts said it was for a lower supply voltage and through me off.).
As for the power supply I'm looking at picking up a PCB, capacitors, and rectifier kit to use with my transformer. The two I'm looking at are:
68 220uF board: 68pcs 75V 220uf Original RUBYCON YXF Capacitor Power supply board kit /PSU kit #0506 13-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
or this 8x 2200uF board: LJM Audio Power supply kit ( 8 X 63V2200UF capacitors) suitable for L20,L12 2,L6,MX50,Quad 405 amp board-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
Any thoughts on which would be best? Or other suggestions?
Thanks.
Old 16th November 2013, 06:09 PM   #776
gootee is offline gootee  United States
Transformer output of 38 VAC RMS will give a peak of 53.7 Volts but then you have to subtract two diode drops.
Look at the rectifier datasheet and find the voltage drop (Vf, "Forward Voltage") for when the diodes are conducting about 5X your maximum RMS speaker current. (i.e. Assume the speaker current is continuously going. Then assume that the rectifier diodes only conduct for a short time during each cycle, maybe 1/5th of the time. The diodes have to send all of the current, but in 1/5th [or whatever it is] of the time, since they only conduct during the charging pulses, which might be 1/3rd to 1/5th of the time.)
If the diodes could drop 1 Volt each (2 Volts total), for example, then your DC could be as low as 51.7 Volts.
Maybe some bridges use Schottky diodes, which would cut their drop by about half, possibly giving you another Volt or so.
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 16th November 2013, 06:31 PM   #777
Thanks.
I really like the idea of lots of smaller paralleled caps.
But you could build your own cap array, very easily, instead, with no etching required:
If you acquire a bare two-sided PCB, you could drill one hole for each cap, and remove a small ring of copper from around each hole (Dremel tool?), on the top side of the PCB. Then insert one cap lead through a hole and solder on bottom, with other lead bent parallel to top copper and soldered to it.
One side of the PCB would be a supply rail and the other side would be ground.
You could divide one side of a PCB by removing a thin line of copper all the way across, and make two supply rails on one PCB.
The large un-broken copper planes would give VERY low inductance (and ESR). For best impedance characteristics, use very thin PCB; maybe 0.5 mm thickness.
Feed from rectifiers to one edge of the PCB and supply your circuit from the opposite edge.
Don't make the array too long and thin; nearer to square is probably better. And use very short and fat wires to connect board output, so you don't destroy the beautiful low inductance.
There are posts you could find, on diyaudio, where Terry Given proposed this and then built one that he measured with his network analyzer.
Old 17th November 2013, 02:04 PM   #778
doctordata's Avatar
Originally Posted by chienmort View Post
Thank you Rens. Move your tagline BTW.
? Please explain
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 17th November 2013, 04:13 PM   #779
Maybe it was meant to say LOVE instead of MOVE.
Old 17th November 2013, 10:00 PM   #780
doctordata's Avatar
Thanks ! Finally understand what my wife said
New Sure IRS2092 IRFI4020H part # AA-AB32291 HiroPro Class D 28 15th January 2017 09:32 AM
Part Supliers for IRS2092 and IRFI4020H-117P KrishanthaSampath Class D 2 22nd February 2014 02:10 PM
IRS2092 own design elektryk Class D 30 5th February 2014 09:30 AM
L20D IRS2092 basic questions egoaudio Class D 7 8th October 2011 03:46 PM
Design help needed for IRS2092 cmhadley Class D 1 3rd January 2009 12:06 AM
Copyright 1999-2017 diyAudio
